Today I’ve had a down of the server where is installed Juju, after its re-start, the status command that I’ve used of juju (ex. juju status) it didn’t give me any feedback
$:juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
aws-controller wordpress admin superuser aws/us-east-1 3 1 none 2.6.2
maas-controller openstack admin superuser maas-cloud 3 1 none 2.5.4
openstack-controller* server-cloud admin superuser openstack-cloud/RegionOne 5 1 none 2.5.4
$:juju status
I’ve checked that issue is only for the controller openstack-controller of Juju on Openstack, while for maas-controllers its status works fine.
$: juju status
please enter password for admin on maas-controller:
openstack maas-controller maas-cloud 2.5.4 unsupported 21:46:55Z
ceph-mon 13.2.4+dfsg1 active 3 ceph-mon jujucharms 31 ubuntu
ceph-osd 13.2.4+dfsg1 active 3 ceph-osd jujucharms 273 ubuntu
ceph-radosgw 13.2.4+dfsg1 active 1 ceph-radosgw jujucharms 262 ubuntu
cinder 13.0.3 active 1 cinder jujucharms 276 ubuntu
cinder-ceph 13.0.3 active 1 cinder-ceph jujucharms 238 ubuntu
glance 17.0.0 active 1 glance jujucharms 271 ubuntu
keystone 14.0.1 active 1 keystone jujucharms 288 ubuntu
mysql 5.7.20-29.24 active 1 percona-cluster jujucharms 272 ubuntu
neutron-api 13.0.2 active 1 neutron-api jujucharms 266 ubuntu
neutron-gateway 13.0.2 active 1 neutron-gateway jujucharms 256 ubuntu
neutron-openvswitch 13.0.2 active 3 neutron-openvswitch jujucharms 255 ubuntu
nova-cloud-controller 18.1.0 active 1 nova-cloud-controller jujucharms 316 ubuntu
nova-compute 18.1.0 active 3 nova-compute jujucharms 290 ubuntu
ntp 3.2 active 4 ntp jujucharms 31 ubuntu
openstack-dashboard 14.0.2 active 1 openstack-dashboard jujucharms 271 ubuntu
rabbitmq-server 3.6.10 active 1 rabbitmq-server jujucharms 82 ubuntu
ceph-mon/0 active idle 1/lxd/0 10.20.81.17 Unit is ready and clustered
ceph-mon/1 active idle 0/lxd/2 10.20.81.8 Unit is ready and clustered
ceph-mon/2* active idle 2/lxd/1 10.20.81.23 Unit is ready and clustered
ceph-osd/0 active idle 2 10.20.81.5 Unit is ready (1 OSD)
ceph-osd/1 active idle 1 10.20.81.3 Unit is ready (1 OSD)
ceph-osd/2* active idle 0 10.20.81.4 Unit is ready (1 OSD)
ceph-radosgw/0* active idle 3/lxd/2 10.20.81.18 80/tcp Unit is ready
cinder/0* active idle 1/lxd/1 10.20.81.19 8776/tcp Unit is ready
cinder-ceph/0* active idle 10.20.81.19 Unit is ready
glance/0* active idle 0/lxd/0 10.20.81.20 9292/tcp Unit is ready
keystone/0* active idle 2/lxd/0 10.20.81.22 5000/tcp Unit is ready
mysql/0* active idle 3/lxd/0 10.20.81.16 3306/tcp Unit is ready
neutron-api/0* active idle 1/lxd/2 10.20.81.15 9696/tcp Unit is ready
neutron-gateway/0* active idle 3 10.20.81.6 Unit is ready
ntp/2 active idle 10.20.81.6 123/udp chrony: Ready
nova-cloud-controller/0* active idle 0/lxd/1 10.20.81.7 8774/tcp,8775/tcp,8778/tcp Unit is ready
nova-compute/0* active idle 0 10.20.81.4 Unit is ready
neutron-openvswitch/1 active idle 10.20.81.4 Unit is ready
ntp/1 active idle 10.20.81.4 123/udp chrony: Ready
nova-compute/1 active idle 1 10.20.81.3 Unit is ready
neutron-openvswitch/0* active idle 10.20.81.3 Unit is ready
ntp/0* active idle 10.20.81.3 123/udp chrony: Ready
nova-compute/2 active idle 2 10.20.81.5 Unit is ready
neutron-openvswitch/2 active idle 10.20.81.5 Unit is ready
ntp/3 active idle 10.20.81.5 123/udp chrony: Ready
openstack-dashboard/0* active idle 2/lxd/2 10.20.81.21 80/tcp,443/tcp Unit is ready
rabbitmq-server/0* active idle 3/lxd/1 10.20.81.9 5672/tcp Unit is ready
0 started 10.20.81.4 os-compute02 bionic Openstack Deployed
0/lxd/0 started 10.20.81.20 juju-dda9d5-0-lxd-0 bionic Openstack Container started
0/lxd/1 started 10.20.81.7 juju-dda9d5-0-lxd-1 bionic Openstack Container started
0/lxd/2 started 10.20.81.8 juju-dda9d5-0-lxd-2 bionic Openstack Container started
1 started 10.20.81.3 os-compute01 bionic Openstack Deployed
1/lxd/0 started 10.20.81.17 juju-dda9d5-1-lxd-0 bionic Openstack Container started
1/lxd/1 started 10.20.81.19 juju-dda9d5-1-lxd-1 bionic Openstack Container started
1/lxd/2 started 10.20.81.15 juju-dda9d5-1-lxd-2 bionic Openstack Container started
2 started 10.20.81.5 os-compute03 bionic Openstack Deployed
2/lxd/0 started 10.20.81.22 juju-dda9d5-2-lxd-0 bionic Openstack Container started
2/lxd/1 started 10.20.81.23 juju-dda9d5-2-lxd-1 bionic Openstack Container started
2/lxd/2 started 10.20.81.21 juju-dda9d5-2-lxd-2 bionic Openstack Container started
3 started 10.20.81.6 os-compute04 bionic Openstack Deployed
3/lxd/0 started 10.20.81.16 juju-dda9d5-3-lxd-0 bionic Openstack Container started
3/lxd/1 started 10.20.81.9 juju-dda9d5-3-lxd-1 bionic Openstack Container started
3/lxd/2 started 10.20.81.18 juju-dda9d5-3-lxd-2 bionic Openstack Container started
