juju metadata generate-image -d ~/simplestreams -i {os_iamge_id} after this command it is showing following error:
panic: empty value for "controller-uuid" found in configuration (type <nil>, val <nil>)
Yes, I am using Juju 2.6. ah , last time I used Juju 2.5 client. thank you.
And in Juju 2.6, after created a controller it is not showing all clouds list by running:
juju clouds
I think it is another bug…
