unit-vault-1: 08:59:13 ERROR unit.vault/1.juju-log Unable to find implementation for relation: peers of vault-ha
unit-vault-mysql-router-1: 08:59:59 ERROR unit.vault-mysql-router/1.juju-log Unable to find implementation for relation: requires of juju-info
unit-vault-mysql-router-1: 09:00:14 ERROR unit.vault-mysql-router/1.juju-log db-router:7: Unable to find implementation for relation: requires of juju-info
unit-vault-mysql-router-1: 09:00:14 ERROR unit.vault-mysql-router/1.juju-log db-router:7: Failed to connect to database due to ‘(2003, “Can’t connect to MySQL server on ‘127.0.0.1:3306’ (111)”)’
unit-vault-mysql-router-1: 09:00:15 ERROR unit.vault-mysql-router/1.juju-log db-router:7: Failed to connect to database due to ‘(2003, “Can’t connect to MySQL server on ‘127.0.0.1:3306’ (111)”)’
unit-vault-1: 09:00:16 ERROR unit.vault/1.juju-log shared-db:8: Unable to find implementation for relation: peers of vault-ha
unit-vault-1: 09:04:21 ERROR unit.vault/1.juju-log shared-db:8: Traceback (most recent call last):
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 174, in _new_conn
conn = connection.create_connection(
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/util/connection.py”, line 96, in create_connection
raise err
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/util/connection.py”, line 86, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File “/usr/lib/python3.8/http/client.py”, line 1256, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1302, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1251, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1011, in _send_output
self.send(msg)
File “/usr/lib/python3.8/http/client.py”, line 951, in send
self.connect()
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 205, in connect
conn = self._new_conn()
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connection.py”, line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f1582ae4e80>: Failed to establish a new connection: [Errno 111] Connection refused
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/adapters.py”, line 439, in send
resp = conn.urlopen(
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 755, in urlopen
retries = retries.increment(
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/urllib3/util/retry.py”, line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘127.0.0.1’, port=8220): Max retries exceeded with url: /v1/sys/health (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f1582ae4e80>: Failed to establish a new connection: [Errno 111] Connection refused’))
File “/var/lib/juju/agents/unit-vault-1/charm/reactive/vault_handlers.py”, line 765, in _assess_status
health = vault.get_vault_health()
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 339, in wrapped_f
return self(f, *args, **kw)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 430, in call
do = self.iter(retry_state=retry_state)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 378, in iter
raise retry_exc.reraise()
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 206, in reraise
raise self.last_attempt.result()
File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 437, in result
return self.__get_result()
File “/usr/lib/python3.8/concurrent/futures/_base.py”, line 389, in __get_result
raise self._exception
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/tenacity/init.py”, line 433, in call
result = fn(*args, **kwargs)
File “/var/lib/juju/agents/unit-vault-1/charm/lib/charm/vault.py”, line 267, in get_vault_health
response = requests.get(
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/api.py”, line 76, in get
return request(‘get’, url, params=params, **kwargs)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/api.py”, line 61, in request
return session.request(method=method, url=url, **kwargs)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/sessions.py”, line 542, in request
resp = self.send(prep, **send_kwargs)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/sessions.py”, line 655, in send
r = adapter.send(request, **kwargs)
File “/var/lib/juju/agents/unit-vault-1/.venv/lib/python3.8/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘127.0.0.1’, port=8220): Max retries exceeded with url: /v1/sys/health (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f1582ae4e80>: Failed to establish a new connection: [Errno 111] Connection refused’))
unit-vault-mysql-router-1: 09:04:22 ERROR unit.vault-mysql-router/1.juju-log Unable to find implementation for relation: requires of juju-info
unit-vault-mysql-router-1: 09:04:23 ERROR unit.vault-mysql-router/1.juju-log Failed to connect to database due to ‘(2003, “Can’t connect to MySQL server on ‘127.0.0.1:3306’ (111)”)’
unit-vault-1: 09:04:34 ERROR unit.vault/1.juju-log Unable to find implementation for relation: peers of vault-ha
every openstack service which has its own mysql-router get this error
please i need help
