Juju is not able to start lxc containers on remote machines
It looks like there is a regression with new netplan 0.107 version under 22.04. Now juju can not start lxd containers due to following error:
2024-10-12 09:10:24 ERROR juju.worker.lxdprovisioner provisioner_task.go:1304 cannot start instance for machine "7/lxd/3": failed to bridge devices: bridge activation error: yaml: unmarshal errors:
  line 10: cannot unmarshal !!str 0 into int
  line 12: cannot unmarshal !!str 100 into int
  line 15: cannot unmarshal !!str 0 into int
  line 32: cannot unmarshal !!str 0 into int
  line 34: cannot unmarshal !!str 100 into int
  line 37: cannot unmarshal !!str 0 into int
  line 53: cannot unmarshal !!str 15 into int
  line 112: field openvswitch not found in type netplan.VLAN
  line 126: field openvswitch not found in type netplan.VLAN
  line 140: field openvswitch not found in type netplan.VLAN
  line 154: field openvswitch not found in type netplan.VLAN
  line 161: field openvswitch not found in type netplan.VLAN
  line 168: field openvswitch not found in type netplan.VLAN
The generated netplan is following:
https://pastebin.canonical.com/p/ZfGfCvRx5d/
It looks like new netplan renders network config configuration received from maas cloud-init differently then previous version.
To allow lxc container creation following changes had to be done to the netplan file:
  1. Change string values to int values:
mii-monitor-interval: "100"  -> 100
up-delay: "0" -> 0
down-delay: "0" -> 0
  1. Comment out openvswitch: {} from the vlan definition:
br-data.3219:
      addresses:
  - "X.X.X.X/22"
  mtu: 9000
  link: "br-data"
# openvswitch: {}
Are you aware about any changes introduced in netplan 0.107 which uses string instead of int in bond parameter values and adding openvswitch: {} under vlan section?
This seems to be a juju netplan parsing issue: Bug #2084444 “juju can not parse new 50-cloud-init.yaml properly...” : Bugs : Netplan
