But I don’t want the dashboard listening only on “localhost” but also on the machine’s physical IP. Using lsof -i :31666 confirms that it is only listening on localhost.
I can’t find a flag to specify an IP or card, etc.
Everything seems to be running correctly
$ juju machines
0 started 10.20.172.175 juju-287e40-0 ubuntu@22.04 Running
1 started 10.20.172.168 juju-287e40-1 ubuntu@20.04 Running
The machine is on a 192.168.1.0/24 network so I also tried
Hi, in Juju 3, the dashboard is accessed via a ssh tunnel set up by the juju dashboard command. The command listens on localhost:31666 as you point out.
This is to allow the browser to connect to a http address and thus avoid the recent browser restrictions on self signed certs, whilst still having encrypted traffic to the dashboard itself.
Perhaps I’m missing something in the documentation.
You can’t just connect to “localhost” from a remote system and if that system is behind a firewall - it makes sense to port forward the web traffic, not ssh traffic.
$ juju status
gives
controller/0* active idle 0 10.20.172.175
juju-dashboard/0* active idle 1 `10.20.172.168 8080`/tcp
Since juju dashboard only allows connections to localhost I could
SNAT to 10.20.172.168:8080 from a remotely reachable IP address
Put a HAProxy (or Apache I suppose) interface on that same machine and proxy inbound data to localhost:31666
create a SSH bridge
Not as ideal as being able to specify the dashboard , but at least I can view the dashboard remotely easily, just noting that the 8080 traffic is unencrypted so having a HAproxy system in front of it allowed remote browser access via encrypted end-to-end traffic.
The juju dashboard command is expected to be run on the same machine where your web browser is. It opens a secure tunnel to the dashboard api endpoint and proxies a localhost connection to that endpoint. This allows a browser on the same host to connect to http localhost to reach the dashboard. The alternative is to connect directly to the actual dashboard endpoint with http but this is insecure and the browser rightly warns about it.
If you are using some sort of bastion host to run the Juju CLI and want to run the browser on a different host, we sort of assume you have the networking skills to set this up (as you have done) because it’s not a use case we cater for out of the box. The expected common use case is to have the Juju CLI installed and run locally.
