Is there a way to specify the target nodes in MAAS cloud for OpenStack bundle deployment? Tried both ‘-to’ as well as ’ --map-machines ’ options without success.
In your file bundle.yaml :
machines: “1”: constraints: tags=compute-node0 “2”: constraints: tags=compute-node1 “3”: constraints: tags=compute-node3
tags=name for your node in your MAAS cloud.
Thank you. Will try.
