Juju debug-code
(added in Juju 2.8)
Maybe this is just a section of https://discourse.charmhub.io/t/debugging-charm-hooks/1116
Many of our charms are written in python, which has nice facilities for live debugging of code pdb. For the Operator Framework, we wanted to provide a nice way to not just get a shell where you can run the hook from bash, but actually drop you all the way into a pdb shell.
For charmers, the main difference between juju debug-hooks and juju debug-code is that once the tmux session is established, it executes the hook as normal, but with the environment variable JUJU_DEBUG_AT set. Charms can look for that environment variable and chose to drop into a debugger based on the value.
Hook names
Like juju debug-hooks, juju debug-code takes a list of hooks to debug, and will run all other hooks as normal. (eg, if you just want to debug config-changed, you can specify juju debug-code unit/0 config-changed.) This helps developers avoid having to manually interact with all the other hooks that Juju might fire before running the one they are interested in debugging.
JUJU_DEBUG_AT
The Charm is responsible for interpreting the meaning of the environment variable JUJU_DEBUG_AT. The default set by juju is "all". Users can set a different value by supplying juju debug-code --at LOCATION.
Operator Framework
For Operator Framework charms, the framework interprets the string as a comma separated list of named breakpoints, with reserved keywords for all and hook. Charm developers can create their own breakpoints by calling self.framework.breakpoint(name=None), passing an optional name.
For the default value of all, the python interpreter will drop into pdb for each handler of a hook, and for the all named and unnamed breakpoints that are encountered while running the code.
If the value is set to hook, then only the handlers for a given Juju hook will trigger a breakpoint. Unnamed and named breakpoints will be skipped.
