Hi all,
I have hit a dead end. whenever i try to add machines or deploy applications using juju. The controller machines fails to get published images meta data. It keeps on pointing to link1. this url is not accessible anymore. The installation use to work well but after Jan 1 2024 things have changes it does not works they way it was working.
I am trying install juju applications of LXD cluster
link 1
http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson
link 2
https://cloud-images.ubuntu.com/releases/
LXD version
Client version: 5.19
Server version: 5.19
JUJU version’
3.3.0-genericlinux-amd64 (tried on the classic 3.1.7 it dod not work either)
OS Jammy 22.04
Solns tried:
Hosted my own meta data internal site with pache2 it skips and defaults to
link1
Changed juju version—same error
Tried with Ubuntu 20.04—same error
Boostraped the controller with link2 —same error
error
4-01-05 23:44:14 WARNING juju.worker.proxyupdater proxyupdater.go:297 unable to update apt mirrors: exit status 1, output: “”
2024-01-05 23:44:48 INFO juju.worker.logforwarder logforwarder.go:105 config change - log forwarding not enabled
2024-01-05 23:44:48 INFO juju.worker.upgrader upgrader.go:166 desired agent binary version: 3.3.0
2024-01-05 23:49:29 INFO juju.state addmachine.go:506 new machine “1” has preferred addresses: private “”, public “”
2024-01-05 23:50:30 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting “link1”: Get “link1”: dial tcp 185.125.190.40:80: i/o timeout
2024-01-05 23:51:01 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting “link1”: Get “link1”: dial tcp 185.125.190.37:80: i/o timeout
2024-01-05 23:51:33 WARNING juju.environs.simplestreams datasource.go:212 Got error requesting “link1”: Get “link1”: dial tcp 185.125.190.40:80: i/o timeout
manadart
(Joseph Phillips)
10 January 2024 12:54
2
There is logic to fall back from index2 to index if not found. It isn’t clear why this is not happening.
Can you change you model’s logging configuration to include juju.environs.simplestreams=DEBUG and try another deployment?
Hi ,
Thank you for your response!
I added it still I cannot see any debug logs
juju model-config -m test logging-config=“juju.environs.simplestreams=DEBUG”
controller-0: 17:17:07 DEBUG juju.worker.logger reconfiguring logging from “=DEBUG” to “juju.environs.simplestreams=DEBUG”
machine-23: 17:17:07 DEBUG juju.worker.logger reconfiguring logging from “=DEBUG” to “juju.environs.simplestreams=DEBUG”
unit-nginx-0: 17:17:07 DEBUG juju.worker.logger reconfiguring logging from “=DEBUG” to “juju.environs.simplestreams=DEBUG”
controller-0: 17:21:00 ERROR juju.worker.provisioner 26 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.40:80: i/o timeout
controller-0: 17:23:38 ERROR juju.worker.provisioner 27 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.40:80: i/o timeout
controller-0: 17:25:13 ERROR juju.worker.provisioner 28 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.37:80: i/o timeout
controller-0: 17:27:14 ERROR juju.worker.provisioner 29 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.40:80: i/o timeout
controller-0: 17:32:31 ERROR juju.worker.provisioner 30 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.37:80: i/o timeout
controller-0: 17:35:35 ERROR juju.worker.provisioner 31 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.37:80: i/o timeout
controller-0: 17:37:18 ERROR juju.worker.provisioner 32 cannot get available image metadata: failed getting published images metadata from default ubuntu cloud images: cannot read index data, attempt count exceeded: cannot access URL “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: Get “http://cloud-images.ubuntu.com/releases/streams/v1/index2.sjson ”: dial tcp 185.125.190.40:80: i/o timeout
controller-0: 17:43:06 INFO juju.worker.provisioner provisioning in zones: [fgdk8sqa-node1 fgdk8sqa-node2 fgdk8sqa-node3 fgdk8sqa-node4 fgdk8sqa-node5 fgdk8sqa-node6]
controller-0: 17:43:06 INFO juju.worker.provisioner found machine pending provisioning id:33, details:33
manadart
(Joseph Phillips)
11 January 2024 10:17
4
Continued on Launchpad here .
