Hello ,
I am facing issue while bootstrapping Juju Controller.
Juju Controller is currently a VM on MAAS KVM POD. Juju Bootstrap process gets stucked at “Running machine configuration script…”
Have configured NATing and Routing as below.
sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
sudo iptables -A FORWARD -i eth0 -o br1 -m state \
--state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i br1 -o eth0 -j ACCEPT
echo 'net.ipv4.ip_forward=1' | sudo tee -a /etc/sysctl.conf
sudo sysctl -p
juju bootstrap --bootstrap-series=focal --constraints tags=juju nxtgen-poc nxtgen-poc-controller
Creating Juju controller “nxtgen-poc-controller” on nxtgen-poc/default
Looking for packaged Juju agent version 2.8.9 for amd64
Launching controller instance(s) on nxtgen-poc/default…
- empwes (arch=amd64 mem=4G cores=2)
Installing Juju agent on bootstrap instance
Fetching Juju Dashboard 0.3.0
Waiting for address
Attempting to connect to 192.168.30.3:22
Connected to 192.168.30.3
/var/log/cloud-init.log
2021-03-21 19:34:08,272 - util.py[DEBUG]: Creating symbolic link from
‘/run/cloud-init/result.json’ =>
‘…/…/var/lib/cloud/data/result.json’ 2021-03-21 19:34:08,272 -
util.py[DEBUG]: Reading from /proc/uptime (quiet=False) 2021-03-21
19:34:08,273 - util.py[DEBUG]: Read 12 bytes from /proc/uptime
2021-03-21 19:34:08,273 - util.py[DEBUG]: cloud-init mode ‘modules’
took 10.367 seconds (10.37) 2021-03-21 19:34:08,273 -
handlers.py[DEBUG]: finish: modules-final: SUCCESS: running modules
for final 2021-03-21 19:34:08,273 - url_helper.py[DEBUG]: [0/1] open
‘http://192-168-30-0--24.maas-internal:5248/MAAS/metadata/status/empwes’
with {‘url’:
‘http://192-168-30-0--24.maas-internal:5248/MAAS/metadata/status/empwes’,
‘allow_redirects’: True, ‘method’: ‘POST’, ‘headers’:
{‘Authorization’: ‘OAuth oauth_nonce=“32825240929956351451616355248”,
oauth_timestamp=“1616355248”, oauth_version=“1.0”,
oauth_signature_method=“PLAINTEXT”,
oauth_consumer_key=“YgQFkxTVeyzVFqsUyV”,
oauth_token=“jpFZfGNB7h45bMQP8P”,
oauth_signature="%26VYsvZ78qgC86KKLKm7vrUtCwnrQsSbHM"’}} configuration
2021-03-21 19:34:08,291 - url_helper.py[DEBUG]: Read from
(204, 0b) after 1 attempts
Please help to solve this issue.
