Hi!I got this problem.
Any suggestions for prodding the the application so that it can move forward? Perhaps a config setting?
And I try to use juju debug-hook ,but i got this :Juju command “debug-hooks” not supported on kubernetes models
It looks like your k8s cluster (in this case MicroK8s) is having problems provisioning the instances.
What does the output of microk8s kubectl get pods -n ran
give you? And if it lists any containers there, what does microk8s kubectl describe pod -n ran $pod-name
give (where $pod-name is the name of a particular pod)?
If you’re able to share the charms you’re using (it looks like they’re deployed from the charmstore, so possibly they’re public?) I can also test deploying them here too.
Thanks for your support!
I got the containers like this:
root@admin:~# microk8s kubectl get pods -n ran NAME READY STATUS RESTARTS AGE ue-67b76bc7d5-4wvl8 0/1 Init:0/1 0 17h ue-operator-0 1/1 Running 1 17h modeloperator-68757b4f79-8764l 1/1 Running 1 17h ran-operator-0 1/1 Running 1 17h
It looks like the ue-67b76bc7d5-4wvl8 is having problems。
I deployed them from charms:https://github.com/charmed-osm/5g-ran Using the charmstore
Hello @han93,
Have you enabled multus in Microk8s?
Okay, I will test it myself and in order to reproduce it, and will get back to you ASAP.
I will try to answer this week, but I cannot promise because we are very busy in the OSM hackfest.
Sorry for the inconvenience
I appreciate it.Hope to receive your good news.
And I will keep going to solve this problem.
HEY! Have you test it? Sorry for the inconvenience
Hello @han93,
I didn’t have time to be honest. We have an OSM release coming up, and I have a ton of work to do.
Let’s do this, the 1st of November I should have enough time to test it, and fix it if it is necessary. I will give you an update by then.
Sorry for the inconvenience, David
