I am following this documentation to enable the Ceph Dashboard. Here is the result.
And also i followed this documentation to enable the Ceph dashboard.
This is the output…
Can someone help me with this?
Is there any charm for ceph dashboard?
This is the output…
Yes, the problem is due to the ceph-dashboard charm not being promulgated (to make the deployment proceed by referencing the charm’s simple name). This is because the charm is in tech-preview (not stable).
The documentation you cited has now been updated. Sorry for the trouble.
The doc change is that the application, at its current state of development (for the next six months), should be deployed in this way:
juju deploy cs:~openstack-charmers/ceph-dashboard
Instead of what you tried:
juju deploy ceph-dashboard
There is also a change pending for the charm README.
Is there any update since the last post? I tried to enable dashboard with the latest cloud-archive version of Ceph (17.2.5) with no luck. The error message is that any manager can enable this function.
Can you show us exactly how you deployed the Ceph charms? Are the Juju machines all running Jammy?
Hi, exact yaml looks like this. All hosts are focal:
series: focal
applications:
ceph-mon:
charm: ceph-mon
channel: quincy/stable
num_units: 3
to:
- 5
- 6
- 7
options:
source: cloud:focal-yoga
bindings:
"": data
admin: data
bootstrap-source: data
client: data
cluster: data
mds: data
mon: data
nrpe-external-master: data
osd: data
prometheus: data
public: data
radosgw: data
rbd-mirror: data
ceph-osd:
charm: ceph-osd
num_units: 8
to:
- 14
- 15
- 16
- 17
- 19
- 20
- 21
- 22
options:
osd-devices: /dev/sdb
bindings:
"": data
cluster: data
mon: data
public: data
secrets-storage: data
Should I change/update something?
Hi,
you could use the ceph-dashboard charm to enable and configure the dashboard:
juju deploy --channel quincy/stable ceph-dashboard
juju add-relation ceph-dashboard:dashboard ceph-mon:dashboard
Also cf. Charmhub | Deploy Ceph Dashboard using Charmhub - The Open Operator Collection for config details
