I am trying to bootstrap a cluster to install k8s. I already added my MAAS cluster on juju and now I can’t bootstrap. Here is my output:
rabjen@controller:~$ juju bootstrap minilama --debug --config=config.yaml
09:42:16 INFO juju.cmd supercommand.go:57 running juju [2.6.10 gc go1.10.4]
09:42:16 DEBUG juju.cmd supercommand.go:58 args: []string{"/snap/juju/9484/bin/juju", "bootstrap", "minilama", "--debug", "--config=config.yaml"}
09:42:16 DEBUG juju.cmd.juju.commands bootstrap.go:1038 authenticating with region "" and credential "rabjen" ()
09:42:16 DEBUG juju.cmd.juju.commands bootstrap.go:1166 provider attrs: map[]
09:42:18 INFO cmd authkeys.go:114 Adding contents of "/home/rabjen/.local/share/juju/ssh/juju_id_rsa.pub" to authorized-keys
09:42:18 INFO cmd authkeys.go:114 Adding contents of "/home/rabjen/.ssh/id_rsa.pub" to authorized-keys
09:42:18 DEBUG juju.cmd.juju.commands bootstrap.go:1225 preparing controller with config: map[type:maas max-action-results-size:5G transmit-vendor-metrics:true ftp-proxy: apt-no-proxy: agent-metadata-url: image-stream:released snap-store-proxy-url: agent-stream:released snap-store-proxy: container-image-stream:released test-mode:false no-proxy:127.0.0.1,localhost,::1 snap-http-proxy: juju-no-proxy:127.0.0.1,localhost,::1 uuid:4c1b9b28-f797-4a38-8ee2-969a6b117140 logforward-enabled:false juju-ftp-proxy: logging-config: net-bond-reconfigure-delay:17 development:false fan-config: resource-tags: apt-ftp-proxy: enable-os-upgrade:true http-proxy:http://192.168.42.250:3128 automatically-retry-hooks:true disable-network-management:false apt-mirror: snap-store-assertions: name:controller image-metadata-url: container-inherit-properties: ignore-machine-addresses:false https-proxy:http://192.168.42.250:3128 max-status-history-age:336h authorized-keys:ssh-rsa (redacted) juju-client-key
ssh-rsa (redacted) rabjen@controller
proxy-ssh:false juju-https-proxy: juju-http-proxy: max-action-results-age:336h apt-https-proxy:http://192.168.42.250:3128 update-status-hook-interval:5m provisioner-harvest-mode:destroyed ssl-hostname-verification:true default-series:bionic cloudinit-userdata: enable-os-refresh-update:true container-networking-method: max-status-history-size:5G container-image-metadata-url: firewall-mode:instance backup-dir: egress-subnets: apt-http-proxy:http://192.168.42.250:3128 snap-https-proxy:]
09:42:18 DEBUG juju.provider.maas environprovider.go:62 opening model "controller".
09:42:18 INFO cmd bootstrap.go:677 Creating Juju controller "minilama" on minilama
09:42:18 INFO juju.cmd.juju.commands bootstrap.go:746 combined bootstrap constraints:
09:42:18 DEBUG juju.environs.bootstrap bootstrap.go:262 model "controller" supports application/machine networks: true
09:42:18 DEBUG juju.environs.bootstrap bootstrap.go:264 network management by juju enabled: true
09:42:18 INFO cmd bootstrap.go:296 Loading image metadata
09:42:18 INFO cmd bootstrap.go:373 Looking for packaged Juju agent version 2.6.10 for amd64
09:42:18 INFO juju.environs.bootstrap tools.go:72 looking for bootstrap agent binaries: version=2.6.10
09:42:18 DEBUG juju.environs.tools tools.go:102 finding agent binaries in stream: "released"
09:42:18 DEBUG juju.environs.tools tools.go:104 reading agent binaries with major.minor version 2.6
09:42:18 DEBUG juju.environs.tools tools.go:112 filtering agent binaries by version: 2.6.10
09:42:18 DEBUG juju.environs.tools tools.go:118 filtering agent binaries by architecture: amd64
09:42:18 DEBUG juju.environs.tools urls.go:116 trying datasource "keystone catalog"
09:42:33 DEBUG juju.environs.simplestreams simplestreams.go:683 using default candidate for content id "com.ubuntu.juju:released:tools" are {20161007 mirrors:1.0 content-download streams/v1/cpc-mirrors.sjson []}
09:42:34 INFO juju.environs.bootstrap tools.go:74 found 17 packaged agent binaries
09:42:34 INFO cmd bootstrap.go:467 Starting new instance for initial controller
09:42:34 INFO cmd bootstrap.go:161 Launching controller instance(s) on minilama...
09:42:34 DEBUG juju.provider.maas environ.go:960 attempting to acquire node in zone "default"
09:42:36 DEBUG juju.cloudconfig.instancecfg instancecfg.go:956 Setting numa ctl preference to false
09:42:36 DEBUG juju.service discovery.go:64 discovered init system "systemd" from series "bionic"
09:42:36 DEBUG juju.provider.maas environ.go:1051 maas user data; 3820 bytes
09:42:42 DEBUG juju.provider.maas environ.go:1097 started instance "4cxt8h"
09:42:42 INFO cmd bootstrap.go:235 - 4cxt8h (arch=amd64 mem=16G cores=4)
09:42:42 INFO juju.environs.bootstrap bootstrap.go:805 newest version: 2.6.10
09:42:42 INFO juju.environs.bootstrap bootstrap.go:820 picked bootstrap agent binary version: 2.6.10
09:42:42 INFO cmd bootstrap.go:509 Installing Juju agent on bootstrap instance
09:42:43 INFO cmd bootstrap.go:626 Fetching Juju GUI 2.15.0
09:49:43 DEBUG juju.cloudconfig.instancecfg instancecfg.go:956 Setting numa ctl preference to false
Waiting for address
09:49:44 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
Attempting to connect to 192.168.42.101:22
09:49:44 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: ssh: connect to host 192.168.42.101 port 22: Connection refused
09:49:49 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: ssh: connect to host 192.168.42.101 port 22: Connection refused
09:49:54 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: ssh: connect to host 192.168.42.101 port 22: Connection refused
09:49:54 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:04 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:04 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:10 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:14 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:15 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:21 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:24 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:27 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:32 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:34 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:38 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:44 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:44 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:49 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:50:54 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:50:55 DEBUG juju.provider.common bootstrap.go:576 connection attempt for 192.168.42.101 failed: /var/lib/juju/nonce.txt does not exist
09:51:01 INFO cmd bootstrap.go:345 Connected to 192.168.42.101
09:51:01 INFO juju.cloudconfig userdatacfg_unix.go:537 Fetching agent: curl -sSfw 'agent binaries from %{url_effective} downloaded: HTTP %{http_code}; time %{time_total}s; size %{size_download} bytes; speed %{speed_download} bytes/s ' --retry 10 --proxy http://192.168.42.250:3128 --noproxy 127.0.0.1,localhost,::1 -o $bin/tools.tar.gz <[https://streams.canonical.com/juju/tools/agent/2.6.10/juju-2.6.10-ubuntu-amd64.tgz]>
09:51:01 INFO cmd bootstrap.go:415 Running machine configuration script...
09:55:24 INFO cmd bootstrap.go:564 Bootstrap agent now started
09:55:24 DEBUG juju.provider.maas maas2instance.go:87 "node1" has addresses ["local-cloud:192.168.42.101@undefined(id:-1)"]
09:55:24 INFO juju.juju api.go:303 API endpoints changed from [] to [192.168.42.101:17070]
09:55:24 INFO cmd controller.go:89 Contacting Juju controller at 192.168.42.101 to verify accessibility...
09:55:24 INFO juju.juju api.go:67 connecting to API addresses: [192.168.42.101:17070]
10:05:22 ERROR juju.cmd.juju.commands bootstrap.go:697 unable to contact api server after 1 attempts: unable to connect to API: Forbidden
10:05:22 DEBUG juju.cmd.juju.commands bootstrap.go:698 (error details: [{/build/juju/parts/juju/go/src/github.com/juju/juju/cmd/juju/common/controller.go:128: unable to contact api server after 1 attempts} {/build/juju/parts/juju/go/src/github.com/juju/juju/cmd/juju/common/controller.go:44: } {/build/juju/parts/juju/go/src/github.com/juju/juju/juju/api.go:72: } {/build/juju/parts/juju/go/src/github.com/juju/juju/api/apiclient.go:207: } {/build/juju/parts/juju/go/src/github.com/juju/juju/api/apiclient.go:622: } {/build/juju/parts/juju/go/src/github.com/juju/juju/api/apiclient.go:967: } {/build/juju/parts/juju/go/src/github.com/juju/juju/api/apiclient.go:1071: unable to connect to API} {/build/juju/parts/juju/go/src/github.com/juju/juju/api/apiclient.go:1096: } {Forbidden}])
10:05:22 DEBUG juju.cmd.juju.commands bootstrap.go:1332 cleaning up after failed bootstrap
10:05:22 INFO juju.provider.common destroy.go:21 destroying model "controller"
10:05:22 INFO juju.provider.common destroy.go:32 destroying instances
10:05:24 INFO juju.provider.common destroy.go:56 destroying storage
10:05:24 INFO cmd supercommand.go:502 command finished
I have to download things from the net using a proxy, so my config.yaml says:
apt-http-proxy: http://192.168.42.250:3128
apt-https-proxy: http://192.168.42.250:3128
Am I missing anything?
