I had a kubuntu 22.04 LTS machine with LXD + juju setup … the controller suddenly started not being able to reach ubuntus servers
unning apt-get update
Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.91.38), connection timed out Could not connect to archive.ubuntu.com:80 (185.125.190.36), connection timed out
Err:2 http://security.ubuntu.com/ubuntu focal-security InRelease
Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.36), connection timed out Could not connect to security.ubuntu.com:80 (185.125.190.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists...
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Cannot initiate the connection to archive.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.91.39)
it seems to repeat when I wiped out the LXD via sudo snap remove lxd and reinstall sudo snap install lxd and lxd init <with ipv6 bridge off>
even re-installing everything on the LXD side proved to change nothing… is something very wrong with my host machine? Other machines are reaching Ubuntu just fine but not this particular host…
