Hi All,
- Installed juju client on Baremetal
- Initialized lxd with default lxdbr0 10.121.152.1/24
- Created lxc VM
10.121.152.102on the baremetal and attached it as manual-cloud controller.(juju bootstrap manual-cloud) - Created new model and added baremetal
(juju add-machine ssh:user1@10.121.152.1)to that model.
Baremetal machine added successfully but still in pending state.
add-machine of parent host is supported from inside VM? Thank you for the support.
user@baremetal:~$ juju version
3.2.2-genericlinux-amd64
user@baremetal:~$ juju clouds
Only clouds with registered credentials are shown.
There are more clouds, use --all to see them.
Clouds available on the controller:
Cloud Regions Default Type
manual-cloud 1 default manual
localhost 1 localhost lxd 1 built-in LXD Container Hypervisor
manual-cloud 1 default manual 0 local
user@baremetal:~$ lxc list
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
| vm1 | RUNNING | 10.121.152.102 (enp5s0) | | VIRTUAL-MACHINE | 0 |
user@baremetal:~$ juju controllers
Controller Model User Access Cloud/Region Models Nodes HA Version
manual-cloud-default* ceph admin superuser manual-cloud/default 2 1 none 3.2.2
user@baremetal:~$ juju machines -m controller
0 started 10.121.152.102 manual: ubuntu@22.04 Manually provisioned machine
user@baremetal:~$ juju status
ceph manual-cloud-default manual-cloud/default 3.2.2 unsupported 23:23:21+05:30
0 pending 10.121.152.1 manual:10.121.152.1 ubuntu@22.04 Manually provisioned machine
user@baremetal:~$ juju machines -m ceph
