Juju action fail not working in Juju 3.1.5
Hello team,
Using juju 3.1.5 failed actions don’t seem to report correctly. I created the following action to validate this:
def _on_some_action(self, event: ActionEvent) -> None:
        if True:
            event.fail("failed correctly")
            logger.error("failed correctly")
            return None
When I run the action I get the following output only:
Running operation 3 with 1 task
  - task 4 on unit-tls-certificates-operator-0
Waiting for task 4...
However I see the “failed correctly” line in the logs.
Any ideas?
Thank you!
