The Juju team is proud to release Juju 2.9.5 (and 2.9.6 candidate). We aim to be your preferred tool for writing operators, software that manages software, whether your hosting infrastructure is Kubernetes, in the cloud or on-premises.
This release includes important fixes
- LP #1918680 - controller migration when dealing with large deployments
- LP #1899793 - bootstrap fails with TLS handshake timeout
- LP #1929908 - bundle deploys on an existing model causes all units to run config-changed even with no changes
- LP #1930649 - sidecar charms don’t record the cloud service info in the juju model
- LP #1931721 - juju ssh/scp to leader for subordinates
- LP #1931570 - pebble-specific events now allows debug-code
- LP #1927732 - upgrade from 2.8 results in applications with no leader
Additional bugs fixed can be found on the [milestone page](https://launchpad.net/juju/+milestone/2.9.5).
Known Issues
Model upgrades with sidecar charms
Models which contain k8s sidecar charms cannot be upgraded from 2.9.0. This will not be an issue from this 2.9.6 release onwards, but any such workloads running on 2.9.0 will need to be redeployed.
How do I upgrade?
There are three binaries that make up a Juju deployment - the client, the server and the agents. To upgrade a running system:
Upgrade the client
Make sure you have the version of the Juju CLI that you want running across the system (controller and agents in any deployed models). If you installed the Juju snap, it will automatically be updated daily from the channel you selected, but you might want to sudo snap switch juju --channel=2.8/stable for example, to get a particular version. To get the latest binary from your channel:
snap refresh juju
Check version
Make sure that you’re using the Juju version you want.
juju version
Backing up
juju create-backup
Upgrade a Juju server
You can see which servers your client knows about, and their versions, with this command:
juju controllers
Controller ... Version
azure* ... 2.8.3
jaas ... 2.7.6
You can instruct a server to upgrade itself to the latest version:
juju upgrade-controller <controller>
Upgrade deployed agents
Each running model includes a set of Juju agents which manage the communication between your charms and the Juju server. Your model agents remain at the same version until you ask to upgrade them.
juju upgrade-model <model>
The 2.9.6 candidate release contains an important fix
- LP #1929364 - IP address sometimes not set or incorrect on pebble_ready event
Using the candidate release
Installing:
juju bootstrap <cloud> --config agent-stream=proposed
Upgrading a controller:
juju upgrade-controller <controller> --agent-stream=proposed
Upgrading model agents is done as usual.
Further instructions
For detailed information about the upgrade process please see:
- https://discourse.jujucharms.com/t/controller-backups/1106
- https://discourse.jujucharms.com/t/upgrading-models/1154
- https://discourse.jujucharms.com/t/notes-on-upgrading-juju-software/1153
- https://discourse.jujucharms.com/t/troubleshooting-model-upgrades/1186
Feedback Appreciated!
Let us know how you’re using Juju! Please ask questions on discourse.charmhub.io or tweet us @juju_devops with the hashtag #juju_devops.
