The Juju team is proud to release Juju 2.9.10. We aim to be your preferred tool for writing operators, software that manages software, whether your hosting infrastructure is Kubernetes, in the cloud or on-premises.
‘charmhub’ added as logging label
To enable debugging around charmhub within juju use:
juju model-config -m controller "logging-config='#charmhub=TRACE'"
Useful when there are issues with the juju find, juju info, juju download, and juju deploy commands.
This release candidate includes important fixes
- LP#1928778 - Unable to upgrade-charm pod_spec charm to sidecar charm
- LP#1936684 - OOM and high load upgrading to 2.9.7
- LP#1900021 - Controller not caching agent binaries across models
- LP#1936281 - bundle with local metadata v2 k8s sidecar charm fails for “metadata v1”
- LP#1897261 - network-get returns the vip as ingress address
How do I install Juju?
The best way to get a specific release of Juju is to install the snap from the appropriate channel. snap info juju will give you a list of the current channels and the versions published in them. For the latest stable release of Juju:
sudo snap install juju --classic --channel=2.9
The Juju CLI is available for a variety of platforms, including Windows and macOS. Refer to the installation documentation for details.
How do I upgrade?
There are three binaries that make up a Juju deployment - the client, the server and the agents. To upgrade a running system:
Upgrade the client
Make sure you have the version of the Juju CLI that you want running across the system (controller and agents in any deployed models). If you installed the Juju snap, it will automatically be updated daily from the channel you selected, but you might want to sudo snap switch juju --channel=2.9 for example, to get a particular version. To get the latest binary from your channel:
snap refresh juju --channel=2.9
Check version
Make sure that you’re using the Juju version you want.
juju version
Backing up
juju create-backup
Upgrade a Juju server
You can see which servers your client knows about, and their versions, with this command:
juju controllers
Controller ... Version
azure* ... 2.8.3
jaas ... 2.7.6
You can instruct a server to upgrade itself to the latest version:
juju upgrade-controller <controller>
How to upgrade the controller
Upgrade deployed agents
Each running model includes a set of Juju agents which manage the communication between your charms and the Juju server. Your model agents remain at the same version until you ask to upgrade them.
juju upgrade-model <model>
How to upgrade your model(s)
Further instructions
For detailed information about the upgrade process please see:
- https://discourse.jujucharms.com/t/controller-backups/1106
- https://discourse.jujucharms.com/t/upgrading-models/1154
- https://discourse.jujucharms.com/t/notes-on-upgrading-juju-software/1153
- https://discourse.jujucharms.com/t/troubleshooting-model-upgrades/1186
Feedback Appreciated!
Let us know how you’re using Juju! Please ask questions on discourse.charmhub.io, tweet us @juju_devops with the hashtag #juju_devops, and chat with us at #juju on Freenode.
