Juju 2.8.3 Hotfix Release Notes
Release Juju 2.8.3 – Hotfix Release
Today, we are releasing Juju 2.8.3. This is a hotfix release for the 2.8 series, which addresses an issue upgrading from 2.8.1 to 2.8.2.
This release includes fixes to the following issues:
  • LP #1895954 - SEGV when jujud restarts after upgrade-controller 2.8.1 -> 2.8.2
Known issues
Fixing a broken 2.8.2 Upgrade
If you are experiencing a failure to upgrade, and find messages like this in your controller machine-*.log files, you are probably experiencing the issue:
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x40 pc=0x1d031ca]
goroutine 460 [running]:
github.com/juju/juju/state.ResetDefaultRelationLimitInCharmMetadata.
We have a workaround for people impacted by this bug.
How do I install Juju?
Other packages are available for a variety of platforms, including Windows and macOS. Refer to the full Juju installation documentation.
Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
How do I upgrade?
Upgrading Juju is a multi-step process:
If you are upgrading Juju from 2.8.0 and have either a Kubernetes Juju controller or a Kubernetes Models the following steps will need to be performed
  • upgrade the client (the Juju binary that you interact with on the command-line)
  • (recommended) verify that the client upgrade was successful
  • (recommended) back up the controller
  • upgrade the controller
  • upgrade models
Upgrade the client
If you’ve installed Juju via the snap, your Juju will automatically be installed overnight. To force the update, run:
snap refresh juju
Check version
To prevent any confusion in later steps, ensure that you’re using the new Juju version.
juju version
Backing up
juju create-backup
Upgrading controllers
Juju includes a command that instructs the controller to upgrade itself to the latest version.
juju upgrade-controller
How to upgrade the controller
Upgrade models
Your models remain at the same version until you have explicitly told Juju to upgrade them.
juju upgrade-model
How to upgrade your model(s)
Further instructions
Juju’s documentation pages provide detailed information about the upgrade process:
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message to our Twitter account @juju_devops, tweet using the hashtag #juju_devops, and chat with us at #juju on Freenode.
