The Juju team is proud to release Juju 2.8.10!
This is a bug-fix release for the 2.8 series.
This release includes important fixes
- LP #1918695 - Migration of large models does not complete due to timeout
- LP #1910989 - Juju injecting unwanted metadata in Resources deployed by K8s Charm
- LP #1918742 - Error in bundle causes juju to panic
- LP #1918204 - Need a consistent means to know the hostname of a machine
- LP #1916746 - juju show-status-log shows only one entry while multiple hooks have been executed
- LP #1915057 - cannot fetch instance information warning message not helpful
- LP #1914098 - juju bootstrap on aws failed while setting up groups
Other improvements
Kubernetes Model Admission
With this release Juju will no longer try to intercept and modify Kubernetes objects of AccessReview to the Juju model. This fixes a serious bug where some workloads where not able to start due to these checks failing.
How do I upgrade?
There are three binaries that make up a Juju deployment - the client, the server and the agents. To upgrade a running system:
Upgrade the client
Make sure you have the version of the Juju CLI that you want running across the system (controller and agents in any deployed models). If you installed the Juju snap, it will automatically be updated daily from the channel you selected, but you might want to sudo snap switch juju --channel=2.8/stable for example, to get a particular version. To get the latest binary from your channel:
snap refresh juju
Check version
Make sure that you’re using the Juju version you want.
juju version
Backing up
juju create-backup
Upgrade a Juju server
You can see which servers your client knows about, and their versions, with this command:
juju controllers
Controller ... Version
azure* ... 2.8.3
jaas ... 2.7.6
You can instruct a server to upgrade itself to the latest version:
juju upgrade-controller <controller>
How to upgrade the controller
Upgrade deployed agents
Each running model includes a set of Juju agents which manage the communication between your charms and the Juju server. Your model agents remain at the same version until you ask to upgrade them.
juju upgrade-model <model>
How to upgrade your model(s)
Further instructions
For detailed information about the upgrade process please see:
- https://discourse.jujucharms.com/t/controller-backups/1106
- https://discourse.jujucharms.com/t/upgrading-models/1154
- https://discourse.jujucharms.com/t/notes-on-upgrading-juju-software/1153
- https://discourse.jujucharms.com/t/troubleshooting-model-upgrades/1186
Feedback Appreciated!
Let us know how you’re using Juju! Please ask questions on discourse.charmhub.io, tweet us @juju_devops with the hashtag #juju_devops, and chat with us at #juju on Freenode.
