The Juju team is proud to release Juju 2.7.7! This is a bugfix release for the 2.7 series.
This release includes fixes to the following issues:
- LP #1831580 - wrong etcd_connection_string on kubernetes-master charm
- LP #1859121 - kvm-based units are ignoring container-image-metadata-url
- LP #1879663 - Removing a machine should remove any series-upgrade side-effects
LP #1875590 - using
instance-type
contraints parameter with string containing spaces character - LP #1878510 - ifupdown used in preference to netplan if both exist
- LP #1882573 - diff-bundle results in runtime error
- LP #1883176 - do not apply lxd profiles to (kvm) manual machine in an lxdcloud model
The full listing can be found in the milestone page. Look for issues classified as “Fix Released”.
How do I install Juju?
Other packages are available for a variety of platforms, including Windows and macOS. Refer to the full Juju installation documentation.
Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
How do I upgrade?
Upgrading Juju is a multi-step process:
- upgrade the client (the Juju binary that you interact with on the command-line)
- (recommended) verify that the client upgrade was successful
- (recommended) back up the controller
- upgrade the controller
- upgrade models
Upgrade the client
If you’ve installed Juju via the snap, your Juju will automatically be installed overnight. To force the update, run:
snap refresh juju
If you’re using the PPA:
sudo apt update
sudo apt upgrade
On Homebrew for macOS:
brew update
brew upgrade
Check version
To prevent any confusion in later steps, ensure that you’re using the new Juju version.
juju version
Check your $PATH
environment variable and that you’ve installed the new version correctly.
On Linux and macOS, use the env
command to inspect the environment. On MS Windows, use SET
Backing up
juju create-backup
Upgrading controllers
Juju includes a command that instructs the controller to upgrade itself to the latest version.
juju upgrade-controller
How to upgrade the controller
First, check that you’re interacting with the intended controller. The juju models
command reports the current controller on the first line.
juju models
To verify what will occur, use the --dry-run
option.
When you’re happy, omit the flag:
Upgrade models
Your models remain at the same version until you have explicitly told Juju to upgrade them.
juju upgrade-model
How to upgrade your model(s)
Check that you’re operating in the correct model. juju model
highlights the current model with an asterisk:
juju models
option.
juju upgrade-juju --dry-run
juju upgrade-juju
Further instructions
Juju’s documentation pages provide detailed information about the upgrade process:
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message to our Twitter account @juju_devops, tweet using the hashtag #juju_devops, and chat with us at #juju on Freenode via IRC or Matrix.
