The Juju team is proud to release Juju 2.7.2!
This is primarily a bug fix release of the stable 2.7 channel., with some additional useful tweaks.
20.04 focal support
It’s now possible to bootstrap and deploy workloads to 20.04 focal images.
Because focal is not yet officially released, you’ll need to use --force
when bootstrapping or deploying charms.
Images may not yet be available for all clouds, and you will need to set the model config attribute image-stream
to daily
, eg for LXD:
juju bootstrap lxd --bootstrap-series focal --model-default image-stream=daily --force
Kubernetes improvements
Cluster scoped custom resources
Custom resource definitions can now be defined to create Cluster scoped resources - previously this was forbidden.
Webhook resources
Charms can now ask to create webhook resources. Add YAML like this to the k8s specific YAML passed to Juju via pod-spec-set
kubernetesResources:
mutatingWebhookConfigurations:
example-mutatingwebhookconfiguration:
- name: "example.mutatingwebhookconfiguration.com"
failurePolicy: Ignore
clientConfig:
service:
namespace: apples
path: /apple
caBundle: "YXBwbGVz"
namespaceSelector:
matchExpressions:
- key: production
operator: DoesNotExist
rules:
- apiGroups:
apiVersions:
- v1
operations:
- CREATE
- UPDATE
resources:
- pods
Controller health check endpoint
The controller has a new health endpoint that returns 200 for a healthy controller and 503 otherwise.
curl -ik https://<controller-ip>:17070/health
HTTP/1.1 200 OK
Date: Mon, 13 Jan 2020 03:28:10 GMT
Content-Length: 8
Content-Type: text/plain; charset=utf-8
vSphere improvements
Users without cluster admin rights can now deploy to vSphere environments. There are 2 key improvements to allow this:
- there’s no need for the user to have read access across the cluster
- a new credential attribute
vmfolder
is used to specify the location of the folder used to store image templates (rather than requiring access to a root folder).
To use the feature, you’ll need access to a writable folder and specify the name of this folder and the vmfolder
attribute of the Juju model’s credential.
Other bug fixes
- LP #1856537 - Filter by Space Name Should Accommodate Name Rules
- LP #1851489 - cannot remove and re-add a manually provisioned machine
- LP #1855777 - segfault due to a badly formatted bundle YAML file
- LP #1783595 - panic if local charms in bundle not found
- LP #1860992 - cross model relation goes into terminated state on deploy
- LP #1860542 - volumeAttachmentPlan in Dying state causes "state changing too quickly
How do I get it?
Other packages are available for a variety of platforms, including Windows and macOS. Please see the online documentation at https://docs.jujucharms.com/reference-install. Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message on Twitter using the hashtag #jujucharms, and chat with us at #juju on Freenode.
