The Juju team is proud to release Juju 2.6.5!
This release addresses several bugs and includes many general improvements.
Warning: pre-upgrade step highly recommended!
Due to the “log collections are now capped” change, the Juju team highly recommends checking the log collection size and pruning the collection.
Log collections are now capped
A new controller config value has been added model-logs-size
. The default size is 20M
. The old logs controller config values of max-logs-size
and max-logs-age
are deprecated and will be removed in 2.7. The conversion to capped collections happens automatically as part of the upgrade.
This addresses the issue where logs may be written into the database faster than we were pruning them, causing disk space issues on the controller machines.
This release includes more important fixes
- LP #1824465 - New units fail provisioning; Juju 2.5.x switches to the Standard SKU (Azure provider)
- LP #1632735 - Trying to bootstrap a region which doesn’t exist gives misleading error
- LP #1833449 - juju register fails with usernames that contain uppercase letters
- LP #1832779 - controller commands fail if there is no active controller
- LP #1834017 - juju bundle upgrade failing with error “branch %q in model %q not found (not found)”
- LP #1831527 - [gce] odd error messages are printed with kill-controller
- LP #1831770 - Storage class error while deploying bundle
- LP #1832783 - k8s init container spec parsing issue
- LP #1832608 - Can’t use DNS for pods in StatefulSet
- LP #1813886 - Unable to remove an offer, claiming removed relation still exists
How do I get it?
The best way to get your hands on this release of Juju is to install it as a
snap package:
sudo snap install juju --classic --channel=2.6/stable
Other packages are available for a variety of platforms, including Windows and macOS. Please see the online documentation at https://docs.jujucharms.com/reference-install. Those subscribed to a snap channel should be automatically upgraded. If you’re using the PPA or Homebrew for macOS, you should see an upgrade available.
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Please ask questions on on Discourse, send us a message on Twitter using the hashtag #jujucharms, and chat with us at #juju on Freenode.
