Juju 2.5.4 Release Notes
The Juju team is proud to release Juju 2.5.4!
This release includes more important fixes
  • LP #1790183 - vSphere cloud provider stuck at Extending the disk
  • LP #1821418 - bundle deployments appear broken under 2.5.2 models
  • LP #1821218 - Juju provisioner server error API mismatch after upgrading MAAS from 1.9 to 2.4.2
How do I get it?
The best way to get your hands on this release of Juju is to install it as a
snap package
Other packages are available for a variety of platforms. Please see the online documentation at https://docs.jujucharms.com/reference-install. Those subscribed to a snap channel should be automatically upgraded. If you’re using the ppa or homebrew, you should see an upgrade available.
Feedback Appreciated!
We encourage everyone to let us know how you’re using Juju. Join us on Discourse at https://discourse.jujucharms.com/, send us a message on Twitter using the hashtag #jujucharms, and join us at #juju on freenode.
