Overview
Duration: 3:00
Before you get started!
Welcome to the world of operators! In this series of tutorials, we will walk you through all the necessary steps to explore and learn operators through some basic examples. Starting with just your laptop, you will learn how to use operators for sophisticated application management at scale, across multiple Kubernetes clusters, cloud virtual machines, and ultimately bare metal.
This tutorial assumes you have successfully completed the previous tutorial - Integration.
What are operators?
Operators are pieces of software designed to drive other software. They encapsulate the operational code of applications, shifting the burden of lifecycle management from configuration files and manual steps to an operator instance. Operators are a form of automation that is gaining popularity in the Kubernetes domain where traditional configuration management does not work. However, operators work with traditional virtual and bare metal machines as well.
What is Juju OLM?
Juju is a universal Operator Lifecycle Manager (OLM) which provides services to operators. It provides resources for operators, deploys them, manages their lifecycle, delivers configuration updates, etc. Juju OLM is universal, meaning that it supports container substrates like Kubernetes as well as traditional machine substrates like bare metal, VMware, OpenStack, or public cloud instances.
In this tutorial, you will learn how to:
Update operators to a newer version
Update applications to a newer version with operators
You will only need:
A machine with 8 GB of RAM
Microk8s and Juju installed
Juju controller bootstrapped on MicroK8s
The Prometheus and Grafana operators deployed to Microk8s
Update operators and applications
Duration: 5:00
Operators and Juju OLM provide lifecycle management capabilities so that applications can be updated in a fully automated way.
In the following steps, we will update the Grafana application with an operator.
First, let’s see what the current status of the model is:
$ juju status
monitoring mk8s microk8s/localhost 2.9.9 unsupported 12:26:52+01:00
App Version Status Scale Charm Store Channel Rev OS Address Message
grafana-k8s grafana/grafana@7f26ece active 1 grafana-k8s charmhub stable 1 kubernetes 10.152.183.126
prometheus-k8s prom/prometheus:latest active 2 prometheus-k8s charmhub stable 1 kubernetes 10.152.183.7
grafana-k8s/0* active idle 10.1.98.61 3000/TCP
prometheus-k8s/0* active idle 10.1.98.51 9090/TCP
prometheus-k8s/1 active idle 10.1.98.5 9090/TCP
In previous tutorials, we deployed a Prometheus and a Grafana operator. Updating a Grafana operator can be achieved by running the following command:
$ juju refresh grafana-k8s
Looking up metadata for charmhub charm "grafana-k8s"
Added charmhub charm "grafana-k8s", revision 2 in channel stable, to the model
Leaving endpoints in "alpha": database, grafana, grafana-dashboard, grafana-source
Notice running microk8s.kubectl get pods -n monitoring will show the newly created pod (age is lower compared to the other pods).
$ microk8s.kubectl get pods -n monitoring
NAME READY STATUS RESTARTS AGE
grafana-k8s-0 1/1 Running 0 35s
If there are no new updates to be received then Juju will return a different result:
ERROR already running latest charm "grafana-k8s"
That’s it. Your Grafana application is already using the latest version of the operator
Next steps
Duration: 2:00
Congratulations! You have reached the end of this tutorial.
You can now move to the next tutorial - “7. Teardown”.
In this tutorial you have learnt how to:
