Overview
Duration: 3:00
Before you get started!
Welcome to the world of operators! In this series of tutorials, we will walk you through all the necessary steps to explore and learn operators through some basic examples. Starting with just your laptop, you will learn how to use operators for sophisticated application management at scale, across multiple Kubernetes clusters, cloud virtual machines and ultimately bare metal.
This tutorial assumes you have successfully completed the previous tutorial - “Configuration”.
What are operators?
Operators are pieces of software designed to drive other software. They encapsulate the operational code of applications, shifting the burden of lifecycle management from configuration files and manual steps to an operator instance. Operators are a form of automation that is gaining popularity in the Kubernetes domain where traditional configuration management does not work. However, operators work with traditional virtual and bare metal machines as well.
What is Juju OLM?
Juju is a universal Operator Lifecycle Manager (OLM) which provides services to operators. It provides resources for operators, deploys them, manages their lifecycle, delivers configuration updates, etc. Juju OLM is universal, meaning that it supports container substrates like Kubernetes as well as traditional machine substrates like bare metal, VMware, OpenStack, or public cloud instances.
In this tutorial you will learn how to:
Deploy another application to the existing model with an operator
Map applications to Kubernetes services
Expose applications for an external consumption
You will only need:
A machine with 8 GB of RAM
Microk8s and Juju installed
Juju controller bootstrapped on MicroK8s
Prometheus deployed to MicroK8s with an operator
Duration: 5:00
In the following steps, we will deploy another application to the existing model with an operator. We will use Grafana as an example. Grafana is open source analytics and interactive visualisation web application that can be configured to display the monitoring data that Prometheus gathers in snappy-looking graphics.
First, let’s see what the current status of the model is:
$ juju status
monitoring mk8s microk8s/localhost 2.9.9 unsupported 11:54:30+01:00
App Version Status Scale Charm Store Channel Rev OS Address Message
prometheus-k8s prom/prometheus:latest active 2 prometheus-k8s charmhub stable 1 kubernetes 10.152.183.7
prometheus-k8s/0* active idle 10.1.98.51 9090/TCP
prometheus-k8s/1 active idle 10.1.98.5 9090/TCP
Then deploy Grafana with an operator:
$ juju deploy grafana-k8s
Located charm "grafana-k8s" in charm-hub, revision 1
Deploying "grafana-k8s" from charm-hub charm "grafana-k8s", revision 1 in channel stable
As you know from the previous tutorials, you can monitor the status of deployed applications by executing the juju status command:
$ juju status
Once the Grafana application turns to the “active” state as on the output above, you can consider the deployment to be finished.
Accessing applications over the network
Duration: 5:00
Operators and Juju OLM provide provisioning capabilities so that network resources can be provisioned for applications in a fully automated way to enable access to applications over the network.
In the previous tutorial, we assumed that the Prometheus application is exposed over the network when accessing its admin API. This may not be the case in all environments, though.
Look at the juju status command output and note the IP addresses used by the applications and their units:
NOTE: IP addresses may vary across the environments. In the following steps use IP addresses from your environment rather than the ones presented in this tutorial.
$ juju status
grafana-k8s/0* active idle 10.1.98.59 3000/TCP
They are different. This is because deployed applications are exposed as Kubernetes services, while application units simply inherit their pod’s IP. You can check it by running the kubectl command:
$ microk8s.kubectl get services -n monitoring
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
modeloperator ClusterIP 10.152.183.58 <none> 17071/TCP 19m
prometheus-k8s-operator ClusterIP 10.152.183.240 <none> 30666/TCP 18m
prometheus-k8s ClusterIP 10.152.183.7 <none> 9090/TCP 18m
prometheus-k8s-endpoints ClusterIP None <none> <none> 18m
grafana-k8s-operator ClusterIP 10.152.183.66 <none> 30666/TCP 2m17s
grafana-k8s ClusterIP 10.152.183.126 <none> 3000/TCP 2m
grafana-k8s-endpoints ClusterIP None <none> <none> 2m
Although the service port is not displayed next to the application, it shows up next to each application unit on the juju status command output.
Let’s now try to access the Grafana dashboard. Based on the outputs above we can see that the grafana application is exposed at the IP address of 10.1.98.59 and its port is 3000. Thus, we should be able to access the Grafana dashboard at the 10.1.98.59:3000 URL. Pass it to your browser and the following page should show up:
Grafana comes with a default admin user, which has the following credentials “admin”/“admin”.
As you can see, in our local deployment on MicroK8s all applications are exposed over the network as Kubernetes services by default. There are some environments, however, like public clouds where applications have to be exposed for external consumption so that public IP addresses could be used to access them over the Internet.
In order to expose an application for external consumption, execute the following command:
$ juju expose grafana-k8s
This command will allocate public IP for the application and configure underlying security groups to enable external traffic.
Next steps
Duration: 2:00
Congratulations! You have reached the end of this tutorial.
You can now move to the next tutorial - “5. Integration”.
In this tutorial you have learnt how to:
