Hi there!
Had a couple of spare minutes last Friday, so I added support for pebble notices to jhack fire.
If you grab the latest/edge snap you should be able to:
jhack fire myapp/0 container-pebble-custom-notice
As you may know, a charm can define multiple custom notices, and the event name alone is therefore not always enough to determine which one to trigger.
Therefore, if your container has a single custom notice, that one will be selected automatically, but in the general case where you have more notices, you’ll have to pass a --notice-id=<some-integer> arg to jhack fire so we know what notice you intend to trigger.
Have no idea what ID your notices have? Fear not:
$ jhack fire tempo/0 tempo-pebble-custom-notice
existing notices for tempo/0:tempo
1: canonical.com/tempo/workload-ready
2: canonical.com/tempo/some-other-notice
[... any more notices that pebble is aware of will be listed here]
select a notice ID to fire (or enter 'abort' to exit): 1
and have the notice canonical.com/tempo/workload-ready fired on your charm.
The next time you invoke the command, you can pass --notice-id=1 to skip the interactive bit.
Have fun!
