How to rotate credentials
Rotate credentials
To rotate credentials for the admin account and invalidate all logged in user sessions, run the
rotate-credentials action.
juju run jenkins-k8s/0 rotate-credentials
The output should look similar to the contents below:
unit-jenkins-k8s-0:
UnitId: jenkins-k8s/0
results:
password: <new password>
status: completed
timing:
completed: <timestamp>
enqueued: <timestamp>
started: <timestamp>
You can use the newly generated password above to access your Jenkins server UI at
http://<UNIT_IP>:8080 as the “admin” user.
