Charm architecture
The jenkins-k8s charm aims to provide core functionalities of Jenkins with horizontally scalable architecture, leveraging its flexible capabilities enhanced by plugins. Operational capabilities are enhanced through integration with the Canonical Observability Stack (COS) charms.
Containers
The core component of jenkins-k8s charm consists of a jenkins-k8s main workload container. The services inside the container are driven by Pebble, a lightweight API-driven process supervisor that controls the lifecycle of a service. Learn more about Pebble and its layer configurations in the Pebble documentation.
C4Context
title Component diagram for the Jenkins charm
Container_Boundary(jenkins, "Jenkins") {
Component(jenkins-app, "Jenkins application", "", "Serves the Jenkins application")
Component(pebble, "Pebble", "", "Starts the Jenkins application")
Rel(pebble, jenkins-app, "")
Container_Boundary(charm, "Jenkins Operator") {
Component(charm, "Jenkins Operator", "", "Jenkins Operator (charm)")
Rel(pebble, charm, "")
Jenkins
This container runs the main workload of the charm. The OCI image is custom built and includes the Jenkins WAR, Java and the Jenkins plugin installation manager.
To facilitate monitoring of the Jenkins application via the COS, the prometheus plugin is installed by default. The instance-identity plugin is also included to ensure seamless registration of agent nodes. Additionally, the monitoring plugin is pre-installed to handle session invalidation.
When a logging relation is joined, a promtail application is started via Pebble which starts
pushing Jenkins logs at /var/lib/jenkins/logs/jenkins.log to Loki.
The metrics are also scraped via accessing the /metrics endpoint of the Jenkins application.
Charm
This container is the main point of contact with the Juju controller. It communicates with Juju to
run necessary charm code defined by the main src/charm.py. The source code is copied to the
/var/lib/juju/agents/unit-UNIT_NAME/charm directory.
OCI image
The jenkins-image is custom built to include Jenkins as well as its plugin installation manager. Since Jenkins is an application running on Java, required libraries and dependencies are installed during the build process.
Jenkins application installation is done at runtime during container pebble ready step.
Currently, Jenkins version 2.492.2 is used alongside Ubuntu 24.04 base image.
Integrations
See Relation endpoints.
Peer relations
Only one deployment per Jenkins application is supported.
Juju events
Juju events allow progression of the charm in its lifecycle and encapsulates part of the execution
context of a charm. Below is the list of observed events for jenkins-k8s charm with how the charm
reacts to the event. For more information about the charm’s lifecycle in general, refer to the
charm’s life documentation.
Event jenkins_pebble_ready
This event signals that the Pebble inside the workload container is ready. The charm then starts interacting with Pebble to begin the installation process.
Event jenkins_home_storage_attached
This event marks the charm’s storage availability. The name of the event derived from the name of
the storage noted in the metadata.yaml configuration under “storage” key.
containers.jenkins.mounts.storage and storage.jenkins-home section. The storage filesystem maps to
/var/lib/jenkins directory of the Jenkins application, which is used to store Jenkins related files.
Event update_status
This event is fired regularly by Juju to check the status of the charm. The charm checks if any plugins outside of the configured plugins (through charm configuration) have been installed and removes them.
Event agent_relation_joined
When an agent joins the relation, the charm registers the Jenkins agent node to the Jenkins application and starts orchestrating it.
Event agent_relation_departed
When an agent departs the relation, the charm unregisters the Jenkins agent node from the Jenkins application.
Charm code overview
The src/charm.py is the default entry point for a charm and has the JenkinsK8sOperatorCharm Python class which inherits from CharmBase.
CharmBase is the base class from which all Charms are formed, defined by Ops (Python framework for developing charms).
See more in the Juju docs: Charm.
The __init__ method guarantees that the charm observes all events relevant to its operation and handles them.
