Jenkins-K8S Charm
jenkins-k8s github src
jenkins-k8s charmstore
For the most part, I was able to follow along the lines of what was done with the other previous k8s charms.
I used filesystem storage for jenkins home https://github.com/jamesbeedy/caas/blob/jenkins_k8s/charms/jenkins/src/metadata.yaml#L22,L24, and defined the TCP ports in the podspec https://github.com/jamesbeedy/caas/blob/jenkins_k8s/charms/jenkins/src/reactive/spec_template.yaml#L7,L9
The docker image for jenkins is built from the upstream jenkins image:
from jenkins/jenkins:2.60.3
# Distributed Builds plugins
RUN /usr/local/bin/install-plugins.sh ssh-slaves
# install Notifications and Publishing plugins
RUN /usr/local/bin/install-plugins.sh email-ext
RUN /usr/local/bin/install-plugins.sh mailer
RUN /usr/local/bin/install-plugins.sh slack
# Artifacts
RUN /usr/local/bin/install-plugins.sh htmlpublisher
# UI
RUN /usr/local/bin/install-plugins.sh greenballs
RUN /usr/local/bin/install-plugins.sh simple-theme-plugin
# Scaling
RUN /usr/local/bin/install-plugins.sh kubernetes
# install Maven
USER root
RUN apt-get update && apt-get install -y maven
USER jenkins
Build the image
docker build . -t jamesbeedy/juju-jenkins-test:1.0
List images see that its there
$ docker image list
REPOSITORY TAG IMAGE ID CREATED SIZE
jamesbeedy/juju-jenkins-test 1.0 0f711167f01c 19 seconds ago 893MB
Build the charm
make build
Push to charmstore
charm push ./build/builds/jenkins-k8s jenkins-k8s --resource jenkins_image=jamesbeedy/juju-jenkins-test:1.0
Everything seems great at this point, although I’m unaware of what other components I may be missing here. I looked at the upstream pod spec for jenkins pod and it seemed pretty simple basically only defining a port, so thats what I did here.
Jenkins-K8S Deployment Process
# Bootstrap AWS
juju bootstrap aws
# Deploy K8S + AWS integrator
juju deploy cs:bundle/canonical-kubernetes-363
juju deploy cs:~containers/aws-integrator-8
# Trust aws-integrator and relate to k8s worker/master
juju trust aws-integrator
juju relate aws-integrator kubernetes-master
juju relate aws-integrator kubernetes-worker
Deployment settles and our k8s is live:
default pdl-aws aws/us-west-2 2.5.0 unsupported 13:52:38-08:00
aws-integrator 1.15.71 active 1 aws-integrator jujucharms 8 ubuntu
easyrsa 3.0.1 active 1 easyrsa jujucharms 195 ubuntu
etcd 3.2.10 active 3 etcd jujucharms 338 ubuntu
flannel 0.10.0 active 5 flannel jujucharms 351 ubuntu
kubeapi-load-balancer 1.14.0 active 1 kubeapi-load-balancer jujucharms 525 ubuntu exposed
kubernetes-master 1.13.2 active 2 kubernetes-master jujucharms 542 ubuntu
kubernetes-worker 1.13.2 active 3 kubernetes-worker jujucharms 398 ubuntu exposed
aws-integrator/1* active idle 11 172.31.102.27 ready
easyrsa/0* active idle 0 172.31.102.85 Certificate Authority connected.
etcd/0* active idle 1 172.31.102.95 2379/tcp Healthy with 3 known peers
etcd/1 active idle 2 172.31.102.73 2379/tcp Healthy with 3 known peers
etcd/2 active idle 3 172.31.102.151 2379/tcp Healthy with 3 known peers
kubeapi-load-balancer/0* active idle 4 172.31.102.181 443/tcp Loadbalancer ready.
kubernetes-master/0* active idle 5 172.31.102.4 6443/tcp Kubernetes master running.
flannel/0* active idle 172.31.102.4 Flannel subnet 10.1.63.1/24
kubernetes-master/1 active idle 6 172.31.102.144 6443/tcp Kubernetes master running.
flannel/1 active idle 172.31.102.144 Flannel subnet 10.1.2.1/24
kubernetes-worker/0* active idle 7 172.31.102.246 80/tcp,443/tcp Kubernetes worker running.
flannel/2 active idle 172.31.102.246 Flannel subnet 10.1.89.1/24
kubernetes-worker/1 active idle 8 172.31.102.192 80/tcp,443/tcp Kubernetes worker running.
flannel/4 active idle 172.31.102.192 Flannel subnet 10.1.34.1/24
kubernetes-worker/2 active idle 9 172.31.102.30 80/tcp,443/tcp Kubernetes worker running.
flannel/3 active idle 172.31.102.30 Flannel subnet 10.1.47.1/24
0 started 172.31.102.85 i-08cc8c6a85f78d6dd bionic us-west-2a running
1 started 172.31.102.95 i-051a93407700bc598 bionic us-west-2a running
2 started 172.31.102.73 i-0663d1baf47487040 bionic us-west-2a running
3 started 172.31.102.151 i-0e84af70f8115f57b bionic us-west-2a running
4 started 172.31.102.181 i-04348b1b743d6048b bionic us-west-2a running
5 started 172.31.102.4 i-02541a9b9bc1efb8a bionic us-west-2a running
6 started 172.31.102.144 i-0998891271a632f3e bionic us-west-2a running
7 started 172.31.102.246 i-09ed2ca17685a2393 bionic us-west-2a running
8 started 172.31.102.192 i-0a74512e86695fbdc bionic us-west-2a running
9 started 172.31.102.30 i-0f488da3b1dfe618a bionic us-west-2a running
11 started 172.31.102.27 i-0ccfa6f129e704b7f bionic us-west-2a running
Now that we have K8S, time to create the Juju k8s model, provision storage, deploy k8s workload.
# Create the K8S cloud and K8S model
juju scp kubernetes-master/0:config ~/.kube/config
kubectl config view --raw | juju add-k8s myk8scloud --cluster-name=juju-cluster
juju add-model bdxk8smodel myk8scloud
# Create the storage pools (operator and application)
juju create-storage-pool operator-storage kubernetes \
storage-class=juju-operator-storage \
storage-provisioner=kubernetes.io/aws-ebs parameters.type=gp2
juju create-storage-pool k8s-ebs kubernetes \
storage-class=juju-ebs \
At this point Juju is configured to deploy the jenkins-k8s charm.
juju deploy cs:~jamesbeedy/jenkins-k8s-0 --storage jenkins-home=1G,k8s-ebs
Wait for the deployment to settle (errors through a bunch of volume creation statuses for a few minutes, but it finally settles).
$ juju status
bdxk8smodel pdl-aws myk8scloud 2.5.0 unsupported 14:05:46-08:00
App Version Status Scale Charm Store Rev OS Address Notes
jenkins-k8s active 1 jenkins-k8s jujucharms 0 kubernetes 10.152.183.104
jenkins-k8s/0* active idle 10.1.47.6 8080/TCP
$ juju storage
Unit Storage id Type Pool Size Status Message
jenkins-k8s/0 jenkins-home/0 filesystem k8s-ebs 42MiB attached Successfully provisioned volume pvc-94699c34-1e8d-11e9-876a-0694b7418256 using kubernetes.io/aws-ebs
kubectl shows me
$ kubectl get namespaces
NAME STATUS AGE
bdxk8smodel Active 32m
default Active 62m
ingress-nginx-kubernetes-worker Active 62m
kube-public Active 62m
kube-system Active 62m
$ kubectl get all --namespace bdxk8smodel
NAME READY STATUS RESTARTS AGE
pod/juju-jenkins-k8s-0 0/1 CrashLoopBackOff 10 31m
pod/juju-operator-jenkins-k8s-0 1/1 Running 0 32m
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
service/juju-jenkins-k8s ClusterIP 10.152.183.104 <none> 8080/TCP 31m
NAME READY AGE
statefulset.apps/juju-jenkins-k8s 0/1 31m
statefulset.apps/juju-operator-jenkins-k8s 1/1 32m
$ kubectl describe pods juju-jenkins-k8s-0 --namespace bdxk8smodel
Namespace: bdxk8smodel
Node: ip-172-31-102-30.us-west-2.compute.internal/172.31.102.30
Start Time: Tue, 22 Jan 2019 13:35:19 -0800
Labels: controller-revision-hash=juju-jenkins-k8s-688b95b7bc
juju-application=jenkins-k8s
juju-controller-uuid=3c1f900d-e056-49dc-8d13-42621a2ae60c
juju-model-uuid=f08a52e5-9645-4f0c-876c-1d01597dc3dc
statefulset.kubernetes.io/pod-name=juju-jenkins-k8s-0
Annotations: <none>
Status: Running
IP: 10.1.47.6
Controlled By: StatefulSet/juju-jenkins-k8s
Containers:
jenkins-k8s:
Container ID: docker://bffdda745ae842a240e68563b7895966b0a63b37b12875c48d78f684ac10c06d
Image: registry.jujucharms.com/jamesbeedy/jenkins-k8s/jenkins_image@sha256:b7d5a693fd458c45178f4793dc5fe2695657f74111885106c36b9f3bd67e68f9
Image ID: docker-pullable://registry.jujucharms.com/jamesbeedy/jenkins-k8s/jenkins_image@sha256:b7d5a693fd458c45178f4793dc5fe2695657f74111885106c36b9f3bd67e68f9
Port: 8080/TCP
Host Port: 0/TCP
State: Waiting
Reason: CrashLoopBackOff
Last State: Terminated
Reason: Error
Exit Code: 1
Started: Tue, 22 Jan 2019 17:27:55 -0800
Finished: Tue, 22 Jan 2019 17:27:55 -0800
Ready: False
Restart Count: 50
Environment: <none>
Mounts:
/var/jenkins_home from juju-jenkins-home-0 (rw)
/var/run/secrets/kubernetes.io/serviceaccount from default-token-sh6f2 (ro)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
juju-jenkins-home-0:
Type: PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
ClaimName: juju-jenkins-home-0-juju-jenkins-k8s-0
ReadOnly: false
default-token-sh6f2:
Type: Secret (a volume populated by a Secret)
SecretName: default-token-sh6f2
Optional: false
QoS Class: BestEffort
Node-Selectors: <none>
Tolerations: node.kubernetes.io/not-ready:NoExecute for 300s
node.kubernetes.io/unreachable:NoExecute for 300s
Events:
Type Reason Age From Message
Warning BackOff 2m12s (x1082 over 3h56m) kubelet, ip-172-31-102-30.us-west-2.compute.internal Back-off restarting failed container
After all is said and done, I’m left wondering how to better introspect the CrashLoopBackOff, and how to configure ingress networking to my application.
For the CrashLoopBackOff, I think I’m best off researching how to debug kubernetes applications.
For the ingress stuff, possibly there a doc/spec on how ingress is done somewhere?
Thanks!
