Jenkins is an open source automation server, providing hundreds of plugins to support building, deploying and automating any project.
For more information on Jenkins see this page.
Plugins Auto Update
If plugins-auto-update is set to True the Jenkins charm will check for new versions of plugins as documented on https://updates.jenkins.io/. Once updated the charm with perform a “safe-restart” to apply the new plugins.
To understand which versions of plugins will be installed you can inspect the update-center.json file from the update-center configuration option.
Navigation
| Level | Path | Navlink |
| 1 | Introduction | |
| 1 | contributing | Contributing |
Redirects
Mapping table
| Path | Location |
