For any problems with this charm, please report bugs here.
The code for this charm can be downloaded as follows:
git clone https://git.launchpad.net/charm-k8s-jenkins-agent
To run tests, simply run make test from within the charm code directory.
Testing the docker image
Deploy Jenkins locally per the section above, including setting the relevant variables,
then build the image locally as follows:
make build-image
docker run --rm -ti --name jenkins-agent-test \
-e JENKINS_API_USER=admin \
-e JENKINS_API_TOKEN="${JENKINS_API_TOKEN}" \
-e JENKINS_URL="http://${JENKINS_IP}:8080" \
-e JENKINS_HOSTNAME="jenkins-agent-test" "jenkins-agent-k8s:devel"
