How to configure installable plugins
Configure jenkins_agent_labels
Use the jenkins_agent_labels configuration to allow assigning different labels to the agent’s node on the Jenkins server.
The configuration is a comma-separated list of node labels. If empty, the agent’s node will have the underlying machine’s architecture as a label by default, for instance x86_64. If this value is configured before any integrations with the Jenkins charm are established, the label will be applied during the node’s creation once an integration has been established.
juju config jenkins-agent jenkins_agent_labels=label1,label2,label3
