Question’s in the title, I have my own opinions but I’m interested in getting more ideas.
Starter for 10
- Authentication
- Juju Storage Support in Hadoop charms
What else?
Starter for 10
What else?
Since there are many possible configs, a more generic custom-config charm option that would allow a user to add/override a set of configs that make it into yarn-site.xml/hdfs-site.xml/core-site.xml might be better then trying to 1:1 match the configs.
+1 for custom configuration through the charms - this is the primary concern users coming from cloudera ask me about Juju BigData “How do I configure the components?”
Cloudera exposes a subset of common configs for each component of the stack in the cloudera manager gui, it would be cool if the charms would allow a user to modify any config using a custom-config option.
This should come alongside the storage bits for obvious reasons (I don’t want data traveling over my mgmt interface DUH).
Cloudera forces a license and charges for support for multi-network feature (even though its just a single configuration)
Easy selling point for Juju BigData over cloudera once these are implemented- (network support, decoupled storage support)
