Issue in deploying kubeflow 1.6 on microk8s
Hi,
I have deployed kubeflow 1,6 using juju on microk8s 1.25 on my laptop running Ubuntu 22.04. The istio-pilot pod is showing following errors. Other services are in waiting state probably because this issue (showing status: List of ingress versions not found for apps: istio-pilot)
Can you please help me with this issue?
2022-10-08 12:22:41 INFO juju.cmd supercommand.go:56 running containerAgent [2.9.34 90e2f047763059f0b8a57941ae0907346464aee8 gc go1.19]
starting containeragent unit command
containeragent unit "unit-istio-pilot-0" start (2.9.34 [gc])
2022-10-08 12:22:41 INFO juju.cmd.containeragent.unit runner.go:556 start "unit"
2022-10-08 12:22:41 INFO juju.worker.upgradesteps worker.go:60 upgrade steps for 2.9.34 have already been run.
2022-10-08 12:22:41 INFO juju.worker.probehttpserver server.go:157 starting http server on [::]:3856
2022-10-08 12:22:41 INFO juju.api apiclient.go:1055 cannot resolve "controller-service.controller-myk8s-localhost.svc.cluster.local": lookup controller-service.controller-myk8s-localhost.svc.cluster.local: operation was canceled
2022-10-08 12:22:41 INFO juju.api apiclient.go:688 connection established to "wss://10.152.183.127:17070/model/3d42a6b1-a24a-4ecc-8bc5-bf071fffd593/api"
2022-10-08 12:22:41 INFO juju.worker.apicaller connect.go:163 [3d42a6] "unit-istio-pilot-0" successfully connected to "10.152.183.127:17070"
2022-10-08 12:22:41 INFO juju.worker.migrationminion worker.go:142 migration phase is now: NONE
2022-10-08 12:22:41 INFO juju.worker.logger logger.go:120 logger worker started
2022-10-08 12:22:41 INFO juju.worker.leadership tracker.go:194 istio-pilot/0 promoted to leadership of istio-pilot
2022-10-08 12:22:42 WARNING juju.worker.proxyupdater proxyupdater.go:282 unable to set snap core settings [proxy.http= proxy.https= proxy.store=]: exec: "snap": executable file not found in $PATH, output: ""
2022-10-08 12:22:42 INFO juju.agent.tools symlinks.go:20 ensure jujuc symlinks in /var/lib/juju/tools/unit-istio-pilot-0
2022-10-08 12:22:42 INFO juju.worker.caasupgrader upgrader.go:113 abort check blocked until version event received
2022-10-08 12:22:42 INFO juju.worker.caasupgrader upgrader.go:119 unblocking abort check
2022-10-08 12:22:42 INFO juju.worker.uniter uniter.go:326 unit "istio-pilot/0" started
2022-10-08 12:22:42 INFO juju.worker.uniter uniter.go:344 hooks are retried true
2022-10-08 12:22:42 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
2022-10-08 12:22:47 INFO juju.worker.uniter resolver.go:145 awaiting error resolution for "install" hook
2022-10-08 12:22:48 INFO juju-log Running legacy hooks/install.
2022-10-08 12:22:51 WARNING install
2022-10-08 12:22:53 WARNING install - Processing resources for Istio core.
2022-10-08 12:22:53 WARNING install ✔ Istio core installed
2022-10-08 12:22:54 WARNING install - Processing resources for Istiod.2022-10-08T12:22:54.590378Z	error	installer	failed to update resource with server-side apply for obj PodDisruptionBudget/kubeflow/istiod: no matches for kind "PodDisruptionBudget" in version "policy/v1beta1"
2022-10-08 12:22:54 WARNING install 2022-10-08T12:22:54.680241Z	error	installer	failed to update resource with server-side apply for obj HorizontalPodAutoscaler/kubeflow/istiod: no matches for kind "HorizontalPodAutoscaler" in version "autoscaling/v2beta1"
2022-10-08 12:22:54 WARNING install ✘ Istiod encountered an error: failed to update resource with server-side apply for obj PodDisruptionBudget/kubeflow/istiod: no matches for kind "PodDisruptionBudget" in version "policy/v1beta1"
2022-10-08 12:22:54 WARNING install failed to update resource with server-side apply for obj HorizontalPodAutoscaler/kubeflow/istiod: no matches for kind "HorizontalPodAutoscaler" in version "autoscaling/v2beta1"
2022-10-08 12:22:55 WARNING install - Pruning removed resources2022-10-08T12:22:55.380478Z	warn	installer	retrieving resources to prune type autoscaling/v2beta1, Kind=HorizontalPodAutoscaler: no matches for kind "HorizontalPodAutoscaler" in version "autoscaling/v2beta1" not found
2022-10-08 12:22:56 WARNING install 2022-10-08T12:22:56.304776Z	warn	installer	retrieving resources to prune type policy/v1beta1, Kind=PodDisruptionBudget: no matches for kind "PodDisruptionBudget" in version "policy/v1beta1" not found
2022-10-08 12:22:59 WARNING install Error: failed to install manifests: errors occurred during operation
2022-10-08 12:22:59 ERROR juju-log Uncaught exception while in charm code:
  File "./src/charm.py", line 333, in <module>
    main(Operator)
  File "/var/lib/juju/agents/unit-istio-pilot-0/charm/venv/ops/main.py", line 424, in main
    framework.reemit()
  File "/var/lib/juju/agents/unit-istio-pilot-0/charm/venv/ops/framework.py", line 746, in reemit
    self._reemit()
  File "/var/lib/juju/agents/unit-istio-pilot-0/charm/venv/ops/framework.py", line 783, in _reemit
    custom_handler(event)
  File "./src/charm.py", line 72, in install
    subprocess.check_call(
  File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['./istioctl', 'install', '-y', '-s', 'profile=minimal', '-s', 'values.global.istioNamespace=kubeflow']' returned non-zero exit status 1.
2022-10-08 12:23:00 ERROR juju.worker.uniter.operation runhook.go:140 hook "install" (via hook dispatching script: dispatch) failed: exit status 1
