What I mean by this
I have a use case that I need an approval workflow to be triggered when someone wants to create/update/delete a resource.
This approval workflow can only be approved/rejected by users with specific permissions to approve/reject.
Example
One developer wants to remove an application from a Kubernetes cluster, so he creates a request.
This request triggers the approval system, and set it to pending
state.
Then, any owner of this application can approve or reject the request, switching it’s state to accepted
or rejected
If the request was accepted, the application is removed.
The actual question
I was studying about some options to fill those requirements and I was trying to understand if it’s possible to use charmed operators to manage this approval workflow. Is it possible?
Sorry for my long answer and such a specific use-case
