Here’s a summary of the work done from 2023-05-08 - 2023-05-19 by IS Charms team related to juju and charming:
- Filed https://github.com/juju/terraform-provider-juju/issues/202 “Add support for juju actions”
- Filed Bug #2018244 “charmhub pages don't use markdown for metadata des...” : Bugs : Canonical Juju “charmhub pages don’t use markdown for metadata description field”
- Filed Bug #2018723 “Charmhub pages with a docs entry no longer have a ...” : Bugs : Canonical Juju “Charmhub pages with a docs entry no longer have a link to ‘help improve’ on root page”
- Added scheduled workflow to update the charm libraries to the operator workflows
- Removed LDAP support for the Indico charm
- Removed legacy db relation from the wordpress-k8s charm
- Fixed Jenkins CI failure due to requests library update
- Filed https://github.com/canonical/charmcraft/issues/1103 “Unable to configure dump plugin with git source”
- New revision of github-runner charm to fix issue with resource leak on LXD instance remove failure and pylxd bug related to websockets.
- Initial jenkins-k8s-operator now is merged to main, with built-in-node builds (to be removed with controller isolation)
