How to troubleshoot IRC bridge issues
This section will help you troubleshoot various issues with the IRC bridge charm.
Synapse stops sending events to the IRC bridge
This section details the issue when Synapse stops sending events to the IRC bridge.
Symptoms
- Synapse is unable to push
appservicetransactions to the IRC bridge. - Synapse logs may indicate errors such as “Server not known” or appservice-specific warnings.
- The database shows
appservice_stream_positionstuck at an old event, and restarting Synapse does not resolve the issue. - Logs from Synapse may contain warnings similar to:
push_bulk to https://chat.example.com/irc threw exception(JSONDecodeError): Expecting value: line 1 column 1 (char 0)
Root cause
The appservice_stream_position in the Synapse database can get stuck on a
problematic event, causing the appservice sender to break silently and stop
processing new events.
Solution
Back up the Synapse database: Before making any changes, ensure you have a full backup of your Synapse database to prevent data loss.
Find more details about the backup in How to Backup and Restore.
Update the
appservice_stream_position: Run the following SQL query to update theappservice_stream_positionto the latest event:UPDATE appservice_stream_position SET stream_ordering = (SELECT MAX(stream_ordering) FROM events); -
Restart Synapse: After executing the query, restart the Synapse service to apply the changes.
Additional notes
- This solution skips the problematic event and allows Synapse to resume sending events to the IRC bridge.
- If the issue persists, check the Synapse logs for additional errors or misconfigurations.
- In this IRC-Bridge issue, you can find more details about the error.
