@billy-olsen
RabbitMQ cluster status is normal, no partition found.
RabbitMQ closing connection issue may be due to rabbitmq file descriptor limit?
RabbitMQ server juju status
root@opc1-maas-openstack:~# juju status rabbitmq-server
openstack maas-controller maas-one/default 2.9.38 unsupported 05:39:28+05:30
rabbitmq-server 3.8.2 active 3 rabbitmq-server 3.9/stable 154 no Unit is ready and clustered
rabbitmq-server/0* active idle 3/lxd/10 10.85.5.75 5672/tcp,15672/tcp Unit is ready and clustered
rabbitmq-server/1 active idle 4/lxd/10 10.85.5.95 5672/tcp,15672/tcp Unit is ready and clustered
rabbitmq-server/2 active idle 5/lxd/10 10.85.5.102 5672/tcp,15672/tcp Unit is ready and clustered
3 started 10.85.2.41 controller-1-nx-opc1-b4-27-11 focal default Deployed
3/lxd/10 started 10.85.5.75 juju-717d4e-3-lxd-10 focal default Container started
4 started 10.85.2.69 controller-2-nx-opc1-b3-39-12 focal default Deployed
4/lxd/10 started 10.85.5.95 juju-717d4e-4-lxd-10 focal default Container started
5 started 10.85.2.62 controller-3-nx-opc1-b2-24-13 focal default Deployed
5/lxd/10 started 10.85.5.102 juju-717d4e-5-lxd-10 focal default Container started
juju ssh rabbitmq-server/0 sudo rabbitmqctl cluster_status
root@opc1-maas-openstack:~# juju ssh rabbitmq-server/0 sudo rabbitmqctl cluster_status
Cluster status of node rabbit@juju-717d4e-3-lxd-10 ...
Basics
Cluster name: rabbit@juju-717d4e-3-lxd-10.maas
Disk Nodes
rabbit@juju-717d4e-4-lxd-10
rabbit@juju-717d4e-5-lxd-10
Running Nodes
Versions
rabbit@juju-717d4e-3-lxd-10: RabbitMQ 3.8.2 on Erlang 22.2.7
rabbit@juju-717d4e-4-lxd-10: RabbitMQ 3.8.2 on Erlang 22.2.7
rabbit@juju-717d4e-5-lxd-10: RabbitMQ 3.8.2 on Erlang 22.2.7
Alarms
(none)
Network Partitions
(none)
Listeners
Node: rabbit@juju-717d4e-3-lxd-10, interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Node: rabbit@juju-717d4e-3-lxd-10, interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Node: rabbit@juju-717d4e-3-lxd-10, interface: [::], port: 15672, protocol: http, purpose: HTTP API
Node: rabbit@juju-717d4e-4-lxd-10, interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Node: rabbit@juju-717d4e-4-lxd-10, interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Node: rabbit@juju-717d4e-4-lxd-10, interface: [::], port: 15672, protocol: http, purpose: HTTP API
Node: rabbit@juju-717d4e-5-lxd-10, interface: [::], port: 25672, protocol: clustering, purpose: inter-node and CLI tool communication
Node: rabbit@juju-717d4e-5-lxd-10, interface: [::], port: 5672, protocol: amqp, purpose: AMQP 0-9-1 and AMQP 1.0
Node: rabbit@juju-717d4e-5-lxd-10, interface: [::], port: 15672, protocol: http, purpose: HTTP API
Feature flags
Flag: drop_unroutable_metric, state: disabled
Flag: empty_basic_get_metric, state: disabled
Flag: implicit_default_bindings, state: enabled
Flag: quorum_queue, state: enabled
Flag: virtual_host_metadata, state: enabled
Connection to 10.85.5.75 closed.
juju ssh rabbitmq-server/1 sudo rabbitmqctl cluster_status
root@opc1-maas-openstack:~# juju ssh rabbitmq-server/1 sudo rabbitmqctl cluster_status
Cluster status of node rabbit@juju-717d4e-4-lxd-10 ...
Basics
Disk Nodes
Running Nodes
Versions
Alarms
(none)
Network Partitions
(none)
Listeners
Feature flags
Connection to 10.85.5.95 closed.
juju ssh rabbitmq-server/2 sudo rabbitmqctl cluster_status
root@opc1-maas-openstack:~# juju ssh rabbitmq-server/2 sudo rabbitmqctl cluster_status
Cluster status of node rabbit@juju-717d4e-5-lxd-10 ...
Basics
Disk Nodes
Running Nodes
Versions
Alarms
(none)
Network Partitions
(none)
Listeners
Feature flags
Connection to 10.85.5.102 closed.
Error from RabbitMQ log
2023-06-26 21:55:03.300 [error] <0.29169.404> closing AMQP connection <0.29169.404> (10.85.5.105:56306 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:03:03.151 [error] <0.1718.405> closing AMQP connection <0.1718.405> (10.85.5.74:46566 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 22:03:25.369 [error] <0.1765.405> closing AMQP connection <0.1765.405> (10.85.5.74:56006 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 22:06:04.960 [error] <0.2372.405> closing AMQP connection <0.2372.405> (10.85.5.105:54118 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:13:20.967 [error] <0.3666.405> closing AMQP connection <0.3666.405> (10.85.5.74:59306 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 22:13:24.879 [error] <0.3682.405> closing AMQP connection <0.3682.405> (10.85.5.74:59320 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 22:17:05.984 [error] <0.4485.405> closing AMQP connection <0.4485.405> (10.85.5.105:33024 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:23:22.345 [error] <0.5637.405> closing AMQP connection <0.5637.405> (10.85.5.74:38340 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 22:28:02.984 [error] <0.6509.405> closing AMQP connection <0.6509.405> (10.85.5.74:38420 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 22:33:03.720 [error] <0.7466.405> closing AMQP connection <0.7466.405> (10.85.5.105:41002 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:33:20.067 [error] <0.7493.405> closing AMQP connection <0.7493.405> (10.85.5.74:45964 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 22:33:23.738 [error] <0.7507.405> closing AMQP connection <0.7507.405> (10.85.5.74:45974 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 22:43:21.381 [error] <0.9398.405> closing AMQP connection <0.9398.405> (10.85.5.105:39706 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:44:03.006 [error] <0.9514.405> closing AMQP connection <0.9514.405> (10.85.5.74:55010 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 22:44:06.455 [error] <0.9529.405> closing AMQP connection <0.9529.405> (10.85.5.74:55024 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 22:53:23.666 [error] <0.10888.405> closing AMQP connection <0.10888.405> (10.85.5.105:59834 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 22:55:04.957 [error] <0.11218.405> closing AMQP connection <0.11218.405> (10.85.5.74:42400 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:03:03.448 [error] <0.12924.405> closing AMQP connection <0.12924.405> (10.85.5.74:43184 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 23:03:27.983 [error] <0.21024.398> closing AMQP connection <0.21024.398> (10.85.5.105:44980 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 23:06:06.214 [error] <0.13529.405> closing AMQP connection <0.13529.405> (10.85.5.74:53598 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:13:21.231 [error] <0.14840.405> closing AMQP connection <0.14840.405> (10.85.5.74:56722 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 23:17:03.256 [error] <0.15660.405> closing AMQP connection <0.15660.405> (10.85.5.105:47306 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 23:23:03.224 [error] <0.16831.405> closing AMQP connection <0.16831.405> (10.85.5.74:44066 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:23:22.928 [error] <0.16862.405> closing AMQP connection <0.16862.405> (10.85.5.74:41106 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 23:28:04.312 [error] <0.17618.405> closing AMQP connection <0.17618.405> (10.85.5.105:39092 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 23:33:14.821 [error] <0.18631.405> closing AMQP connection <0.18631.405> (10.85.5.74:54700 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:33:18.743 [error] <0.18646.405> closing AMQP connection <0.18646.405> (10.85.5.74:35996 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 23:43:03.547 [error] <0.20565.405> closing AMQP connection <0.20565.405> (10.85.5.105:46312 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 23:43:20.993 [error] <0.20582.405> closing AMQP connection <0.20582.405> (10.85.5.74:42318 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:43:24.958 [error] <0.20595.405> closing AMQP connection <0.20595.405> (10.85.5.74:42326 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-26 23:53:21.843 [error] <0.22570.405> closing AMQP connection <0.22570.405> (10.85.5.105:43276 -> 10.85.5.75:5672 - mod_wsgi:342588:8658715a-6e2d-46e0-9d61-cfa098636ffd):
2023-06-26 23:53:23.624 [error] <0.22569.405> closing AMQP connection <0.22569.405> (10.85.5.74:37996 -> 10.85.5.75:5672 - mod_wsgi:477349:63d58461-2572-4161-9cd5-28f2d502d337):
2023-06-26 23:55:02.654 [error] <0.22885.405> closing AMQP connection <0.22885.405> (10.85.5.74:37262 -> 10.85.5.75:5672 - mod_wsgi:477348:06f88160-7915-458c-9e96-3cf39608f776):
2023-06-27 13:39:54.080 [error] <0.21439.328> closing AMQP connection <0.21439.328> (10.85.5.59:34474 -> 10.85.5.75:5672 - nova-compute:171622:476e08c8-5618-4048-bcb6-679c960f55f3):
2023-06-27 18:24:24.203 [error] <0.13485.0> closing AMQP connection <0.13485.0> (10.85.5.52:58082 -> 10.85.5.75:5672 - nova-api-metadata:199250:6559a46b-cc7b-4ac0-88b4-73845b628a01):
2023-06-27 23:56:27.132 [error] <0.5625.414> closing AMQP connection <0.5625.414> (10.85.5.74:59484 -> 10.85.5.75:5672 - mod_wsgi:1084178:f4ca6cfd-d097-4060-bdcb-8934775bbb42):
