Tutorial
This guide provides a step-by-step tutorial on how to deploy the charm and create a backup/restore.
Requirements
The following tutorial requires a Kubernetes Juju controller, such as Canonical K8s. A quick way of doing this is by using the concierge snap.
sudo snap install concierge --classic
sudo concierge prepare -v -p k8s
Deploy
juju add-model velero
# You can use the stable channel when available
juju deploy velero-operator --trust --config use-node-agent=true --channel=edge
juju deploy infra-backup-operator --channel=edge
juju deploy s3-integrator
Integrate
This tutorial uses the s3-integrator charm as the storage provider. Follow its documentation to set up the integrator with the AWS credentials.
If you want to test locally without creating a AWS s3 bucket, you can achieve this by using microceph and enabling rgw. Note that this is for testing proposes and should not be used for production sites:
# optional if you don't have a AWS s3 bucket
sudo snap install microceph
sudo microceph cluster bootstrap
sudo microceph disk add loop,1G,3
sudo microceph enable rgw --port 7480
sudo microceph.radosgw-admin user create --uid test --display-name test
# Save the access_key and secret_key
# Install the s3cmd
sudo apt install s3cmd
# Create a bucket
s3cmd --access_key=<ACCESS_KEY> \
--secret_key=<SECRET_KEY> \
--host=127.0.0.1:7480 \
--host-bucket="127.0.0.1:7480/%(bucket)" \
--no-ssl \
mb s3://my-bucket
# Set the S3-config
juju run s3-integrator/leader sync-s3-credentials access-key=<access_key> secret-key=<secret_key>
# <MICROCEPH_IP> from sudo microceph status
juju config s3-integrator bucket=my-bucket
juju config s3-integrator endpoint=http://<MICROCEPH_IP>:7480
juju config s3-integrator s3-uri-style=path
juju config s3-integrator region="my-region"
Once done, integrate it with Velero Operator:
juju integrate velero-operator s3-integrator
juju integrate infra-backup-operator:cluster-infra-backup velero-operator
juju integrate infra-backup-operator:namespaced-infra-backup velero-operator
After completing these steps you should be able to have a model like this:
velero concierge-k8s k8s 3.6.8 unsupported 16:36:14-03:00
infra-backup-operator active 1 infra-backup-operator 0 10.152.183.162 no Ready
s3-integrator active 1 s3-integrator 1/stable 145 10.152.183.28 no
velero-operator active 1 velero-operator latest/edge 297 10.152.183.75 no Unit is Ready
infra-backup-operator/0* active idle 10.1.0.20 Ready
s3-integrator/0* active idle 10.1.0.153
velero-operator/0* active idle 10.1.0.247 Unit is Ready
Configure your K8s cluster
Create some resources that are under the infra-backup-operator influence. E.g:
kubectl create role pod-reader --verb=get,list --resource=pods
kubectl create clusterrole pod-reader --verb=get,list --resource=pods
Create the Backup
juju run velero-operator/0 create-backup target=infra-backup-operator:cluster-infra-backup
juju run velero-operator/0 create-backup target=infra-backup-operator:namespaced-infra-backup
Simulate a failure/outage
kubectl delete role pod-reader
kubectl delete clusterrole pod-reader
Restore
# list the backups
juju run velero-operator/0 list-backups
backups:
83503892-a24a-409b-b0df-553dcc2465ec:
app: infra-backup-operator
completion-timestamp: "2025-08-08T20:00:28Z"
endpoint: cluster-infra-backup
model: test-charm-9f0e8dda
phase: Completed
start-timestamp: "2025-08-08T20:00:26Z"
85662948-8e5e-4922-8e1c-c5568eafa6e7:
completion-timestamp: "2025-08-07T18:42:13Z"
phase: Completed
start-timestamp: "2025-08-07T18:42:10Z"
# restore the backups
juju run velero-operator/0 restore backup-uid=85662948-8e5e-4922-8e1c-c5568eafa6e7
juju run velero-operator/0 restore backup-uid=83503892-a24a-409b-b0df-553dcc2465ec
# check that the resources were backup
kubectl get role pod-reader
kubectl get clusterrole pod-reader
