Deploy the Indico charm for the first time
What you’ll do
- Deploy the Indico charm.
- Integrate with the Redis K8s charm and the PostgreSQL K8s charm.
- Integrate with Ingress by using NGINX Ingress Integrator.
Through the process, you’ll inspect the Kubernetes resources created, verify the workload state, and log in to your Indico instance.
Requirements
- A working station, e.g., a laptop, with AMD64 architecture.
- Juju 3 installed and bootstrapped to a MicroK8s controller. You can accomplish this process by using a Multipass VM as outlined in this guide: Set up your test environment
- NGINX Ingress Controller. If you’re using MicroK8s, this can be done by running the command
microk8s enable ingress. For more details, see Addon: Ingress.
For more information about how to install Juju, see Get started with Juju.
When using a Multipass VM, make sure to replace 127.0.0.1 IP addresses with the
VM IP in steps that assume you’re running locally. To get the IP address of the
Multipass instance run multipass info my-juju-vm.
Shell into the Multipass VM
NOTE: If you’re working locally, you don’t need to do this step.
To be able to work inside the Multipass VM first you need to log in with the following command:
multipass shell my-juju-vm
Add a Juju model for the tutorial
To manage resources effectively and to separate this tutorial’s workload from your usual work, create a new model in the MicroK8s controller using the following command:
juju add-model indico-tutorial
Since Indico requires connections to PostgreSQL and Redis, you’ll deploy them too. For more information, see Charm Architecture.
Redis is deployed twice because one is for the broker and the other for the cache. To do this, the juju deploy command accepts an extra argument with the custom application name. See more details in juju deploy.
Deploy the charms:
juju deploy postgresql-k8s --trust
juju deploy redis-k8s redis-broker --channel=latest/edge
juju deploy redis-k8s redis-cache --channel=latest/edge
juju deploy indico
To see the pod created by the Indico charm, run kubectl get pods -n indico-tutorial, where the namespace is the name of the Juju model. The output is similar to the following:
NAME READY STATUS RESTARTS AGE
indico-0 3/3 Running 0 6h4m
Run juju status to see the current status of the deployment. In the Unit list, you can see that Indico is waiting:
indico/0* waiting idle 10.1.74.70 Waiting for redis-broker availability
This means that Indico charm isn’t integrated with Redis yet.
Integrate with the Redis k8s charm the PostgreSQL k8s charm
Provide integration between Indico and Redis by running the following juju integrate commands:
juju integrate indico:redis-broker redis-broker
juju integrate indico:redis-cache redis-cache
Run juju status to see that the message has changed:
indico/0* waiting idle 10.1.74.70 Waiting for database availability
Provide integration between Indico and PostgreSQL:
juju integrate indico postgresql-k8s:database
Note: database is the name of the integration. This is needed because establishes that the two charms are compatible with each other. You can run juju info indico to check what are the integration names required by the Indico application.
Enable PostgreSQL extensions:
juju config postgresql-k8s plugin_pg_trgm_enable=true plugin_unaccent_enable=true
Run juju status and wait until the Application status is Active as the following example:
Optional: run juju status --relations --watch 5s to watch the status every five seconds with the Relations section.
indico 3.3 active 1 indico 182 10.152.183.68 no
The deployment finishes when the status shows “Active” for all charms.
Integrate with Ingress by using Nginx ingress integrator charm
The NGINX Ingress Integrator charm can deploy and manage external access to HTTP/HTTPS services in a Kubernetes cluster.
If you want to make Indico charm available to external clients, you need to deploy the NGINX Ingress Integrator charm and integrate Indico with it.
See more details in Deploy the Nginx ingress integrator charm for the first time.
Enable the ingress on MicroK8s first:
sudo microk8s enable ingress
Deploy the charm NGINX Ingress Integrator:
juju deploy nginx-ingress-integrator
To check if RBAC is enabled run the following command:
microk8s status | grep rbac
If it is enabled, then the output should be like the following:
rbac
If the output is empty then RBAC is not enabled.
If your cluster has RBAC enabled, you’ll be prompted to run the following:
juju trust nginx-ingress-integrator --scope cluster
Run juju status to verify the deployment.
Provide integration between Indico and NGINX Ingress Integrator:
juju integrate indico nginx-ingress-integrator
To see the Ingress resource created, run kubectl get ingress on a namespace named for the Juju model you’ve deployed the Indico charm into. The output is similar to the following:
NAME CLASS HOSTS ADDRESS PORTS AGE
indico-local-ingress public indico.local 127.0.0.1 80 2d
Run juju status to see the same Ingress IP in the nginx-ingress-integrator message:
nginx-ingress-integrator active 1 nginx-ingress-integrator stable 45 10.152.183.233 no Ingress IP(s): 127.0.0.1
The browser uses entries in the /etc/hosts file to override what is returned by a DNS server.
Usually a charm default hostname is the application name but since Indico requires a “.” in the hostname for the app to respond, so the charm configures the default to indico.local.
If you are deploying to a local machine you need to add the 127.0.0.1 to the /etc/hosts file. The default hostname for the Indico application is indico.local. To resolve it to your Ingress IP, edit /etc/hosts file and add the following line accordingly:
127.0.0.1 indico.local
Optional: run echo "127.0.0.1 indico.local" >> /etc/hosts to redirect the output of the command echo to the end of the file /etc/hosts.
After that, visit http://indico.local in a browser and you’ll be presented with a screen to create an initial admin account.
Clean up the environment
Well done! You’ve successfully completed the Indico tutorial. To remove the model environment you created during this tutorial, use the following command.
juju destroy-model indico-tutorial --no-prompt --destroy-storage=true
If you used Multipass, to remove the Multipass instance you created for this tutorial, use the following command.
multipass delete --purge my-juju-vm
Finally, remove the 127.0.0.1 indico.local line from the /etc/hosts file.
