@stub @edmund.okumu
I’ve tried to use the k8 lib for redis and found an issue
File "./src/charm.py", line 78, in <module>
main(RedisVmCharm)
File "/var/lib/juju/agents/unit-redis-vm-0/charm/venv/ops/main.py", line 438, in main
_emit_charm_event(charm, dispatcher.event_name)
File "/var/lib/juju/agents/unit-redis-vm-0/charm/venv/ops/main.py", line 150, in _emit_charm_event
event_to_emit.emit(*args, **kwargs)
File "/var/lib/juju/agents/unit-redis-vm-0/charm/venv/ops/framework.py", line 355, in emit
framework._emit(event) # noqa
File "/var/lib/juju/agents/unit-redis-vm-0/charm/venv/ops/framework.py", line 856, in _emit
self._reemit(event_path)
File "/var/lib/juju/agents/unit-redis-vm-0/charm/venv/ops/framework.py", line 931, in _reemit
custom_handler(event)
File "/var/lib/juju/agents/unit-redis-vm-0/charm/lib/charms/redis_k8s/v0/redis.py", line 103, in _on_relation_changed
event.relation.data[self.model.unit]['hostname'] = self._get_master_ip()
File "/var/lib/juju/agents/unit-redis-vm-0/charm/lib/charms/redis_k8s/v0/redis.py", line 119, in _get_master_ip
return socket.gethostbyname(self._charm.current_master)
AttributeError: 'RedisVmCharm' object has no attribute 'current_master'
unit-redis-vm-0: 19:08:58 ERROR juju.worker.uniter.operation hook "redis-relation-changed" (via hook dispatching script: dispatch) failed: exit status 1
Where can I file a bug for the interface ? Deploy Redis using Charmhub - The Open Operator Collection
