runned commands:
juju deploy cs:~openstack-charmers/ceph-dashboard
juju add-relation ceph-dashboard:dashboard ceph-mon:dashboard
juju add-relation ceph-dashboard:certificates vault:certificates
juju status ceph-dashboard:
openstack maas-controller mymaas/default 2.9.28 unsupported 09:40:24+08:00
ceph-dashboard error 3 ceph-dashboard stable 3 no hook failed: "install"
ceph-mon 17.1.0 active 3 ceph-mon quincy/edge 106 no Unit is ready and clustered
ceph-mon/0 active idle 0/lxd/0 10.0.0.161 Unit is ready and clustered
ceph-dashboard/4 error idle 10.0.0.161 hook failed: "install"
ceph-mon/1* active idle 1/lxd/0 10.0.0.185 Unit is ready and clustered
ceph-dashboard/5 error idle 10.0.0.185 hook failed: "install"
ceph-mon/2 active idle 2/lxd/0 10.0.0.179 Unit is ready and clustered
ceph-dashboard/3* error idle 10.0.0.179 hook failed: "install"
ssh to the related unit and check the log:
cat -n /var/log/jujuunit-ceph-dashboard-5.log
1 2022-05-07 01:01:38 INFO juju unit_agent.go:277 Starting unit workers for "ceph-dashboard/5"
2 2022-05-07 01:01:38 INFO juju.worker.apicaller connect.go:163 [6131d3] "unit-ceph-dashboard-5" successfully connected to "10.0.0.214:17070"
3 2022-05-07 01:01:38 INFO juju.worker.apicaller connect.go:260 [6131d3] password changed for "unit-ceph-dashboard-5"
4 2022-05-07 01:01:39 INFO juju.worker.apicaller connect.go:163 [6131d3] "unit-ceph-dashboard-5" successfully connected to "10.0.0.214:17070"
5 2022-05-07 01:01:39 INFO juju.worker.migrationminion worker.go:140 migration phase is now: NONE
6 2022-05-07 01:01:39 INFO juju.worker.logger logger.go:120 logger worker started
7 2022-05-07 01:01:39 ERROR juju.worker.meterstatus runner.go:91 error running "meter-status-changed": charm missing from disk
8 2022-05-07 01:01:39 INFO juju.worker.upgrader upgrader.go:219 no waiter, upgrader is done
9 2022-05-07 01:01:39 INFO juju.worker.uniter uniter.go:334 unit "ceph-dashboard/5" started
10 2022-05-07 01:01:39 INFO juju.worker.uniter uniter.go:637 resuming charm install
11 2022-05-07 01:01:39 INFO juju.worker.uniter.charm bundles.go:78 downloading cs:~openstack-charmers/ceph-dashboard-3 from API server
12 2022-05-07 01:01:41 INFO juju.worker.uniter uniter.go:352 hooks are retried true
13 2022-05-07 01:01:41 INFO juju.worker.uniter.storage resolver.go:127 initial storage attachments ready
14 2022-05-07 01:01:41 INFO juju.worker.uniter resolver.go:154 found queued "install" hook
15 2022-05-07 01:01:42 INFO unit.ceph-dashboard/5.juju-log server.go:327 Running legacy hooks/install.
16 2022-05-07 01:01:42 INFO unit.ceph-dashboard/5.juju-log server.go:327 Installing packages
17 2022-05-07 01:01:46 INFO unit.ceph-dashboard/5.juju-log server.go:327 Installing ['ceph-mgr-dashboard'] with options: ['--option=Dpkg::Options::=--force-confold']
18 2022-05-07 01:01:47 INFO unit.ceph-dashboard/5.juju-log server.go:327 Updating status
19 2022-05-07 01:01:48 ERROR unit.ceph-dashboard/5.juju-log server.go:327 Uncaught exception while in charm code:
20 Traceback (most recent call last):
21 File "./src/charm.py", line 608, in <module>
22 main(CephDashboardCharm)
23 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops/main.py", line 406, in main
24 _emit_charm_event(charm, dispatcher.event_name)
25 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops/main.py", line 140, in _emit_charm_event
26 event_to_emit.emit(*args, **kwargs)
27 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops/framework.py", line 278, in emit
28 framework._emit(event)
29 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops/framework.py", line 722, in _emit
30 self._reemit(event_path)
31 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops/framework.py", line 767, in _reemit
32 custom_handler(event)
33 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops_openstack/core.py", line 105, in on_install
34 self.install_pkgs()
35 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops_openstack/core.py", line 102, in install_pkgs
36 self.update_status()
37 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/ops_openstack/core.py", line 144, in update_status
38 _result = check()
39 File "./src/charm.py", line 363, in check_dashboard
40 if not check_f():
41 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/charms_ceph/utils.py", line 3440, in is_mgr_module_enabled
42 return module in enabled_manager_modules()
43 File "/var/lib/juju/agents/unit-ceph-dashboard-5/charm/venv/charms_ceph/utils.py", line 3428, in enabled_manager_modules
44 modules = json.loads(modules)
45 File "/usr/lib/python3.8/json/__init__.py", line 357, in loads
46 return _default_decoder.decode(s)
47 File "/usr/lib/python3.8/json/decoder.py", line 337, in decode
48 obj, end = self.raw_decode(s, idx=_w(s, 0).end())
49 File "/usr/lib/python3.8/json/decoder.py", line 355, in raw_decode
50 raise JSONDecodeError("Expecting value", s, err.value) from None
51 json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
52 2022-05-07 01:01:48 ERROR juju.worker.uniter.operation runhook.go:146 hook "install" (via hook dispatching script: dispatch) failed: exit status 1
53 2022-05-07 01:01:48 INFO juju.worker.uniter resolver.go:150 awaiting error resolution for "install" hook
54 2022-05-07 01:01:53 INFO juju.worker.uniter resolver.go:150 awaiting error resolution for "install" hook
55 2022-05-07 01:01:53 INFO unit.ceph-dashboard/5.juju-log server.go:327 Running legacy hooks/install.
I have searched ‘charm missing from disk’ in google, but no answer was got.
What’s the problem and how to resolve it? Who can help me please?
