I have deployed openstack-base-70 in local file path before,it worked well ,although without version controled。
But i deployed it in local file path again ,it paused.
root@vivodo-3:~# juju status
openstack maas-controller mymaas/default 2.8.7 unsupported 12:00:11+08:00
ceph-mon 15.2.7 active 3 ceph-mon local 0 ubuntu
ceph-osd 15.2.7 active 3 ceph-osd local 15 ubuntu
ceph-radosgw 15.2.7 waiting 1 ceph-radosgw local 26 ubuntu
cinder 16.2.0 waiting 1 cinder local 136 ubuntu
cinder-ceph 16.2.0 active 1 cinder-ceph local 2 ubuntu
cinder-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
dashboard-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
glance 20.0.1 waiting 1 glance local 150 ubuntu
glance-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
keystone 17.0.0 waiting 1 keystone local 0 ubuntu
keystone-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
mysql-innodb-cluster 8.0.22 waiting 3 mysql-innodb-cluster local 0 ubuntu
neutron-api 16.2.0 waiting 1 neutron-api local 0 ubuntu
neutron-api-plugin-ovn 16.2.0 waiting 1 neutron-api-plugin-ovn local 0 ubuntu
neutron-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
nova-cloud-controller 21.1.0 waiting 1 nova-cloud-controller local 501 ubuntu
nova-compute 21.1.0 active 3 nova-compute local 133 ubuntu
nova-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
ntp 3.5 active 3 ntp local 0 ubuntu
openstack-dashboard 18.3.2 waiting 1 openstack-dashboard local 32 ubuntu
ovn-central 20.03.1 waiting 3 ovn-central local 0 ubuntu
ovn-chassis 20.03.1 waiting 3 ovn-chassis local 0 ubuntu
placement 3.0.0 waiting 1 placement local 0 ubuntu
placement-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
rabbitmq-server 3.8.2 active 1 rabbitmq-server local 150 ubuntu
vault waiting 1 vault local 0 ubuntu
vault-mysql-router 8.0.22 waiting 1 mysql-router local 0 ubuntu
ceph-mon/0 active idle 0/lxd/0 10.0.0.168 Unit is ready and clustered
ceph-mon/1 active idle 1/lxd/0 10.0.0.190 Unit is ready and clustered
ceph-mon/2* active idle 2/lxd/0 10.0.0.183 Unit is ready and clustered
ceph-osd/0* active idle 0 10.0.0.159 Unit is ready (1 OSD)
ceph-osd/1 active idle 1 10.0.0.156 Unit is ready (1 OSD)
ceph-osd/2 active idle 2 10.0.0.157 Unit is ready (1 OSD)
ceph-radosgw/0* waiting idle 0/lxd/1 10.0.0.167 80/tcp Incomplete relations: identity
cinder/0* waiting idle 1/lxd/1 10.0.0.188 8776/tcp Incomplete relations: identity, database
cinder-ceph/0* active idle 10.0.0.188 Unit is ready
cinder-mysql-router/0* waiting idle 10.0.0.188 'db-router' incomplete, MySQL Router not yet bootstrapped
glance/0* waiting idle 2/lxd/1 10.0.0.181 9292/tcp Incomplete relations: identity, database
glance-mysql-router/0* waiting idle 10.0.0.181 'db-router' incomplete, MySQL Router not yet bootstrapped
keystone/0* blocked idle 0/lxd/2 10.0.0.171 5000/tcp Incomplete relations: database, Allowed_units list provided but this unit not present
keystone-mysql-router/0* waiting idle 10.0.0.171 'db-router' incomplete, MySQL Router not yet bootstrapped
mysql-innodb-cluster/0* waiting idle 0/lxd/3 10.0.0.165 'cluster' incomplete, Not all instances configured for clustering
mysql-innodb-cluster/1 maintenance executing 1/lxd/2 10.0.0.191 (install) installing charm software
mysql-innodb-cluster/2 waiting idle 2/lxd/2 10.0.0.182 'cluster' incomplete, Instance not yet configured for clustering
neutron-api/0* waiting idle 1/lxd/3 10.0.0.186 9696/tcp Incomplete relations: identity, database
neutron-api-plugin-ovn/0* waiting idle 10.0.0.186 'certificates' awaiting server certificate data, 'neutron-plugin' incomplete, 'ovsdb-cms' incomplete
neutron-mysql-router/0* waiting idle 10.0.0.186 'db-router' incomplete, MySQL Router not yet bootstrapped
nova-cloud-controller/0* waiting idle 0/lxd/4 10.0.0.170 8774/tcp,8775/tcp Incomplete relations: database, identity
nova-mysql-router/0* waiting idle 10.0.0.170 'db-router' incomplete, MySQL Router not yet bootstrapped
nova-compute/0* active idle 0 10.0.0.159 Unit is ready
ntp/0* active idle 10.0.0.159 123/udp chrony: Ready
ovn-chassis/0* waiting idle 10.0.0.159 'certificates' awaiting server certificate data, 'ovsdb' incomplete
nova-compute/1 active idle 1 10.0.0.156 Unit is ready
ntp/2 active idle 10.0.0.156 123/udp chrony: Ready
ovn-chassis/2 waiting idle 10.0.0.156 'certificates' awaiting server certificate data, 'ovsdb' incomplete
nova-compute/2 active idle 2 10.0.0.157 Unit is ready
ntp/1 active idle 10.0.0.157 123/udp chrony: Ready
ovn-chassis/1 waiting idle 10.0.0.157 'certificates' awaiting server certificate data, 'ovsdb' incomplete
openstack-dashboard/0* waiting idle 1/lxd/4 10.0.0.187 80/tcp,443/tcp Incomplete relations: identity
dashboard-mysql-router/0* waiting idle 10.0.0.187 'db-router' incomplete, MySQL Router not yet bootstrapped
ovn-central/0* waiting idle 0/lxd/5 10.0.0.179 6641/tcp,6642/tcp 'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
ovn-central/1 waiting idle 1/lxd/5 10.0.0.189 6641/tcp,6642/tcp 'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
ovn-central/2 waiting idle 2/lxd/3 10.0.0.185 6641/tcp,6642/tcp 'ovsdb-peer' incomplete, 'certificates' awaiting server certificate data
placement/0* waiting idle 2/lxd/4 10.0.0.184 8778/tcp 'shared-db' incomplete, 'identity-service' incomplete
placement-mysql-router/0* waiting idle 10.0.0.184 'db-router' incomplete, MySQL Router not yet bootstrapped
rabbitmq-server/0* active idle 2/lxd/5 10.0.0.180 5672/tcp Unit is ready
vault/0* waiting idle 0/lxd/6 10.0.0.166 'shared-db' incomplete
vault-mysql-router/0* waiting idle 10.0.0.166 'db-router' incomplete, MySQL Router not yet bootstrapped
0 started 10.0.0.159 node4 focal default Deployed
0/lxd/0 started 10.0.0.168 juju-690d1f-0-lxd-0 focal default Container started
0/lxd/1 started 10.0.0.167 juju-690d1f-0-lxd-1 focal default Container started
0/lxd/2 started 10.0.0.171 juju-690d1f-0-lxd-2 focal default Container started
0/lxd/3 started 10.0.0.165 juju-690d1f-0-lxd-3 focal default Container started
0/lxd/4 started 10.0.0.170 juju-690d1f-0-lxd-4 focal default Container started
0/lxd/5 started 10.0.0.179 juju-690d1f-0-lxd-5 focal default Container started
0/lxd/6 started 10.0.0.166 juju-690d1f-0-lxd-6 focal default Container started
1 started 10.0.0.156 node2 focal default Deployed
1/lxd/0 started 10.0.0.190 juju-690d1f-1-lxd-0 focal default Container started
1/lxd/1 started 10.0.0.188 juju-690d1f-1-lxd-1 focal default Container started
1/lxd/2 started 10.0.0.191 juju-690d1f-1-lxd-2 focal default Container started
1/lxd/3 started 10.0.0.186 juju-690d1f-1-lxd-3 focal default Container started
1/lxd/4 started 10.0.0.187 juju-690d1f-1-lxd-4 focal default Container started
1/lxd/5 started 10.0.0.189 juju-690d1f-1-lxd-5 focal default Container started
2 started 10.0.0.157 node1 focal default Deployed
2/lxd/0 started 10.0.0.183 juju-690d1f-2-lxd-0 focal default Container started
2/lxd/1 started 10.0.0.181 juju-690d1f-2-lxd-1 focal default Container started
2/lxd/2 started 10.0.0.182 juju-690d1f-2-lxd-2 focal default Container started
2/lxd/3 started 10.0.0.185 juju-690d1f-2-lxd-3 focal default Container started
2/lxd/4 started 10.0.0.184 juju-690d1f-2-lxd-4 focal default Container started
2/lxd/5 started 10.0.0.180 juju-690d1f-2-lxd-5 focal default Container started
root@vivodo-3:~# export VAULT_ADDR="http://10.0.0.166:8200"
root@vivodo-3:~# vault operator init -key-shares=5 -key-threshold=3
Error initializing: Put http://10.0.0.166:8200/v1/sys/init: dial tcp 10.0.0.166:8200: connect: connection refused
How can I fix it? thank you a lot.
