See also: Unit testing
This document demonstrates how to write a unit test for Juju.
Contents:
Prepare for the test
Create package_test.go
This step is necessary only if this file doesn’t already exist.
Each package requires a package_test.go file if we wish any of our tests to run.
Below is a standard package_test.go file for an example package called magic. We import the “testing” package from the standard library and then the gocheck package as gc. We also create a function Test that will be the entry-point into our test suites.
// Copyright 20XX Canonical Ltd.
// Licensed under the AGPLv3, see LICENCE file for details.
package magic_test
import (
"testing"
gc "gopkg.in/check.v1"
func Test(t *testing.T) {
gc.TestingT(t)
You will sometimes see package_test.go files which use testing.MgoTestPackage as their entrypoint. This is required to run old-style JujuConnSuite tests, which test against a running instance of MongoDB.
These tests are deprecated and are actively being removed. No more should be added.
Create <code-filename>_test.go
In the code directory, for each file that you want to test (say, a source code file called magic1.go), create a <code-filename>_test.go (e.g. magic1_test.go).
Import gocheck
See also:
gocheck
In magic1_test.go, import the gocheck package as gc:
import (
gc is the usual alias for gocheck across all the Juju repositories.
Add a unit test suite
See also: Unit test suite
Also in magic1_test.go, add a unit test suite.
See more: How to create a unit test suite
Once the test suite structure has been created, it needs to be registered with gc or the tests will not run. You can do by passing a pointer to an instance of our suite to the gc.Suite function.
type magicSuite struct{}
var _ = gc.Suite(&magicSuite{})
Write the test
See also: Checkers
In magic1_test.go, below the test suite, start adding your unit test functions.
The process is as follows: You target some behavior (usually a function) in the code file (in our case, magic1). You then write a test for it, where the test usually follows the same Given, When, Then logic.
For example, suppose your magic1.go file defines a simple function called Sum:
func Sum(a, b int) int {
return a + b
Then, in your magic1_test.go file you can write a test for it as follows (where gc.Equals is a Checker):
// GIVEN a equals 5 AND b equals 3
// WHEN a and b are summed
// THEN we get 8
func (s *magicSuite) TestSum(c *gc.C) {
a := 5
b := 3
res := magic.Sum(a,b)
c.Assert(res, gc.Equals, 8)
Run the test
Finally, to run the test, do:
go test github.com/juju/juju/x/y/magic/
This will run all the tests registered in the magic package, including the one we just wrote.
You can also chose to run specific tests or suites, using the -check.f flag for gocheck
go test github.com/juju/juju/x/y/magic/ -check.f magicSuite # run the magicSuite only
go test github.com/juju/juju/x/y/magic/ -check.f magicSuite.TestSum # run the test TestSum in magicSuite only
See more here gocheck > Selecting which tests to run .
Contributors: @jack-shaw
