The process to upgrade a charm to an specific revision is very straight forward, and the main purpose of this feature is to be able to make bugfixes to an already deployed Canonical Distribution of OSM.
Let’s imagine you are in this status:
grafana-k8s active 1 grafana-k8s jujucharms 13 kubernetes 10.152.183.74
kafka-k8s active 1 kakfa-k8s jujucharms 8 kubernetes 10.152.183.5
keystone-k8s active 1 keystone-k8s jujucharms 8 kubernetes 10.152.183.218
lcm-k8s active 1 lcm-k8s jujucharms 10 kubernetes 10.152.183.59
manodb active 1 mariadb-k8s jujucharms 9 kubernetes 10.152.183.87
mon-k8s active 1 mon-k8s jujucharms 9 kubernetes 10.152.183.62
mongodb-k8s active 1 mongodb-k8s jujucharms 8 kubernetes 10.152.183.107
nbi-k8s active 1 nbi-k8s jujucharms 10 kubernetes 10.152.183.131
pol-k8s active 1 pol-k8s jujucharms 9 kubernetes 10.152.183.158
prometheus-k8s active 1 prometheus-k8s jujucharms 9 kubernetes 10.152.183.96
ro-k8s active 1 ro-k8s jujucharms 9 kubernetes 10.152.183.6
ui-k8s active 1 ui-k8s jujucharms 21 kubernetes 10.152.183.99
vimdb active 1 mariadb-k8s jujucharms 9 kubernetes 10.152.183.186
zookeeper-k8s active 1 zookeeper-k8s jujucharms 11 kubernetes 10.152.183.57
grafana-k8s/1* active idle 10.1.1.107 3000/TCP configured
kafka-k8s/1* active idle 10.1.1.101 9092/TCP configured
keystone-k8s/1* active idle 10.1.1.100 5000/TCP configured
lcm-k8s/1* active idle 10.1.1.108 80/TCP configured
manodb/1* active idle 10.1.1.94 3306/TCP configured
mon-k8s/1* active idle 10.1.1.103 8000/TCP configured
mongodb-k8s/1* active idle 10.1.1.95 27017/TCP configured
nbi-k8s/1* active idle 10.1.1.105 9999/TCP configured
pol-k8s/1* active idle 10.1.1.104 80/TCP configured
prometheus-k8s/1* active idle 10.1.1.106 9090/TCP configured
ro-k8s/1* active idle 10.1.1.102 9090/TCP configured
ui-k8s/1* active idle 10.1.1.109 80/TCP configured
vimdb/1* active idle 10.1.1.99 3306/TCP configured
zookeeper-k8s/1* active idle 10.1.1.98 2181/TCP,2888/TCP,3888/TCP configured
If you want to upgrade the ui-k8s to the revision number 22, you just need to execute the following command:
$ juju upgrade-charm ui-k8s --revision 22
You will see this result after a minute:
ui-k8s active 1 ui-k8s jujucharms 22 kubernetes 10.152.183.99
ui-k8s/2* active idle 10.1.1.109 80/TCP configured
