Unseal a sealed unit
In the circumstance that a Vault unit restarts, you will have to manually unseal it. This guide walks you through the necessary steps:
Starting from a cluster where one unit is sealed:
$ juju status
demo localhost-localhost localhost/localhost 3.4.0 unsupported 12:34:35-04:00
vault blocked 3 vault 1.15/beta 257 no Waiting for Vault to be unsealed
vault/0* active idle 0 10.191.126.116
vault/1 active idle 1 10.191.126.151
vault/2 blocked idle 2 10.191.126.90 Waiting for Vault to be unsealed
0 started 10.191.126.116 juju-b8368f-0 ubuntu@22.04 Running
1 started 10.191.126.151 juju-b8368f-1 ubuntu@22.04 Running
2 started 10.191.126.90 juju-b8368f-2 ubuntu@22.04 Running
Set the VAULT_ADDR variable to the sealed unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml | awk '/public-address/ { print $2 }'):8200; echo $VAULT_ADDR
Unseal the the unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
The units will go back to the active/idle state:
$ juju status
demo localhost-localhost localhost/localhost 3.4.0 unsupported 12:39:11-04:00
vault active 3 vault 1.15/beta 257 no
vault/2 active idle 2 10.191.126.90
