Scale
The Vault charm uses the raft backend to scale. This guide walks you through scaling Vault.
Pre-requisites:
- Vault is initialised and unseal
- The Vault charm is authorised
1. Validate that Vault is an active state
Run juju status:
demo localhost-localhost localhost/localhost 3.4.0 unsupported 12:11:19-04:00
vault active 1 vault 1.15/beta 257 no
vault/0* active idle 0 10.191.126.116
0 started 10.191.126.116 juju-b8368f-0 ubuntu@22.04 Running
2. Scale Vault to 3 units
Add 2 more units:
juju add-unit vault -n 2
The new units will be sealed:
demo localhost-localhost localhost/localhost 3.4.0 unsupported 12:19:14-04:00
vault blocked 3 vault 1.15/beta 257 no Waiting for Vault to be unsealed
vault/1 blocked idle 1 10.191.126.151 Waiting for Vault to be unsealed
vault/2 blocked idle 2 10.191.126.90 Waiting for Vault to be unsealed
1 started 10.191.126.151 juju-b8368f-1 ubuntu@22.04 Running
2 started 10.191.126.90 juju-b8368f-2 ubuntu@22.04 Running
Set the VAULT_ADDR variable to the vault/1 unit:
export VAULT_ADDR=https://$(juju status vault/1 --format=yaml | awk '/public-address/ { print $2 }'):8200; echo $VAULT_ADDR
Unseal the the vault/1 unit using the same unseal keys as received during the initialization of the Vault leader:
vault operator unseal EJoB62t286mjUpSQYZg3mOla3lz/bbElVL5OLnj+rpE=
And complete the same operations for the vault/2 unit:
export VAULT_ADDR=https://$(juju status vault/2 --format=yaml | awk '/public-address/ { print $2 }'):8200; echo $VAULT_ADDR
3. Validate that all units are part of the cluster
All units should go to the Active/Idle Juju status:
$ juju status
demo localhost-localhost localhost/localhost 3.4.0 unsupported 12:24:32-04:00
vault active 3 vault 1.15/beta 257 no
vault/1 active idle 1 10.191.126.151
vault/2 active idle 2 10.191.126.90
And they should all be part of the raft cluster:
$ vault operator raft list-peers
Node Address State Voter
demo-vault/0 10.191.126.116:8201 leader true
demo-vault/1 10.191.126.151:8201 follower true
demo-vault/2 10.191.126.90:8201 follower true
