See also:
Removing a cloud definition can be done locally or, since v.2.6.1, remotely (on a controller). Here, we’ll show how to do it locally (client cache).
A cloud definition can be removed with:
juju remove-cloud [options] <cloud-name>
For example:
juju remove-cloud --local lxd-remote
The following attempted removals will cause the command to error out, accompanied by appropriate messaging:
- a remote private cloud currently in use
- a local or remote built-in cloud
In versions prior to v.2.6.1 the remove-cloud command only operates locally (there is no --local option).
