We created k8s with juju and by default it created two masters. The whole cluster is running in LXD containers on one physical server so there is no point in having multiple masters.
How do I reduce with juju number of masters to just one ?
To answer my own question - I used
juju remove-unit kubernetes-master/1
but now have the following:
$ juju status
default bob-controller localhost/localhost 2.9.32 unsupported 15:33:21Z
containerd go1.13.8 active 2 containerd stable 178 no Container runtime available
easyrsa 3.0.1 active 1 easyrsa stable 420 no Certificate Authority connected.
etcd 3.4.5 active 3 etcd stable 634 no Healthy with 3 known peers
flannel 0.11.0 active 2 flannel stable 597 no Flannel subnet 10.1.38.1/24
kubeapi-load-balancer 1.18.0 active 1 kubeapi-load-balancer stable 844 yes Loadbalancer ready.
kubernetes-master 1.22.15 error 2 kubernetes-master stable 1078 no hook failed: "loadbalancer-internal-relation-broken"
kubernetes-worker 1.22.15 waiting 1 kubernetes-worker stable 816 yes Waiting for cluster credentials.
easyrsa/0* active idle 0 10.50.30.221 Certificate Authority connected.
etcd/0 active idle 1 10.50.30.201 2379/tcp Healthy with 3 known peers
etcd/1 active idle 2 10.50.30.248 2379/tcp Healthy with 3 known peers
etcd/2* active idle 3 10.50.30.219 2379/tcp Healthy with 3 known peers
kubeapi-load-balancer/0* active idle 4 10.50.30.237 443/tcp,6443/tcp Loadbalancer ready.
kubernetes-master/0 active idle 5 10.50.30.243 6443/tcp Kubernetes master running.
containerd/4* active idle 10.50.30.243 Container runtime available
flannel/4 active idle 10.50.30.243 Flannel subnet 10.1.34.1/24
kubernetes-master/1* error idle 6 10.50.30.250 6443/tcp hook failed: "loadbalancer-internal-relation-broken"
kubernetes-worker/0* waiting idle 7 10.50.30.204 80/tcp,443/tcp Waiting for cluster credentials.
containerd/1 active idle 10.50.30.204 Container runtime available
flannel/1* active idle 10.50.30.204 Flannel subnet 10.1.38.1/24
0 started 10.50.30.221 juju-e1704d-0 focal Running
1 started 10.50.30.201 juju-e1704d-1 focal Running
2 started 10.50.30.248 juju-e1704d-2 focal Running
3 started 10.50.30.219 juju-e1704d-3 focal Running
4 started 10.50.30.237 juju-e1704d-4 focal Running
5 started 10.50.30.243 juju-e1704d-5 focal Running
6 started 10.50.30.250 juju-e1704d-6 focal Running
7 started 10.50.30.204 juju-e1704d-7 focal Running
How do I fix the hook failed: "loadbalancer-internal-relation-broken" ?
