Juju generally has multiple versions in concurrent development, and we keep a separate Git branch for each. Often, a bug fix or change needs to happen in multiple versions. In this case, we target the fix to the lowest relevant version, and later merge the patch forward into later versions.
For example, for a bug that affects Juju 3.1, 3.2 and 3.3, we target the original fix to the 3.1 branch, then merge this patch forward into 3.2, then 3.3, making changes as needed.
You should make a habit of following up your patches with a forward merge, especially if they are complex changes, or create merge conflicts.
This document will describe how to do a forward merge. In the following example, we will consider a merge of 2.9 into 3.1 - but you can replace these with any source and target branch.
Ensure your local copies of the source and target branch are up-to-date.
git pull 2.9 git pull 3.1 -
Create a new merge branch based on the target branch. We suggest giving this a descriptive name such as
merge-SRC-TGT-YYYYMMDD.git checkout -b 'merge-2.9-3.1-20231231' '3.1' -
Merge the source branch into your new merge branch.
git merge 2.9 -m 'Merge 2.9 into 3.1' -
If there are no merge conflicts, the above command will merge the branches and create a merge commit. Skip to step 6.
If there are merge conflicts, you will have to resolve these manually. Your IDE might have tools to assist here. After resolving conflicts in a file, run
git add <file>to add it to the index. Then, rungit merge --continueto finish the merge. -
Push your branch to GitHub and open a new PR to the target branch. In the PR description, please include a list of the patches being merged, and list any merge conflicts you encountered.
Exercise: write a Bash script to automate the above process.
